my XB wont start!!!!!!!!!!!!!!
Old Aug 6, 2014 | 03:15 AM
EmanBass's Avatar
Default my XB wont start!!!!!!!!!!!!!!
today i went over to the lot only to find out it wont start -_-... the battery is fine ( i have 3) the terminal in the front battery is a lil rusty but voltage is above 12.7 .. i checked the starter fuse aswell as the am2 fuse its not burned
next i took out the starter relay and made a jumper (short) between terminal 3 and 5 ... and still nothing .... should i switch the starter???? starter selonoid ????
Old Aug 8, 2014 | 07:02 PM
unicxb's Avatar
is it trying to turn over?
Old Aug 8, 2014 | 07:45 PM
FlintMica17's Avatar
Any clicking noises when the key is turned?
Old Aug 8, 2014 | 10:56 PM
EmanBass's Avatar
No nothing happens
Old Aug 8, 2014 | 10:57 PM
EmanBass's Avatar
No I think I hear the fuel pump
Old Aug 9, 2014 | 12:31 AM
Most times when the starter solenoid is at fault you will hear a single click sound when turning the key. If you are hearing nothing i would begin to look at power and ground, or possible security system issue. Speaking of, do you have aftermarket security installed?
Old Aug 9, 2014 | 01:28 PM
EmanBass's Avatar
[QUOTE=FlintMica17;4155637]Most times when the starter solenoid is at fault you will hear a single click sound when turning the key. If you are hearing nothing i would begin to look at power and ground, or possible security system issue. Speaking of, do you have aftermarket security installed?[/QUOTE
i do hear a click , but it sounds like a relay making contact , sounds like a spark going on , but i hear that when i put the key in acc
Jordly221
Feb 13, 2019 05:29 PM
sere
Scion xD Drivetrain & Power
Mar 23, 2015 03:50 AM
mw1957
Mar 16, 2015 06:00 PM
cid_mcdp
Jan 5, 2015 02:45 PM
BV19869
Dec 11, 2014 06:05 PM
