2007 tC Rev Limit
Old Dec 3, 2006 | 03:00 AM
adg016's Avatar
Default 2007 tC Rev Limit
Searched but couldn't find the maximum engine speed for the '07. Anyone know for certain the answer, and have a source?? Thanks.
Old Dec 3, 2006 | 03:06 AM
CuRiOuSfIsH's Avatar
I believe it's 6600 or so, this is based off a dyno sheet from a stock 07 auto. There is 1 member w/ an 07 that has bounced off the limiter a few times... dont remember his username. I have taken my car up to 6500 a few times but never passed that point.
Old Dec 3, 2006 | 07:04 AM
adg016's Avatar
6,500 in your car, eh? Anyone else confirm max permissible engine speed before cut?
Old Dec 3, 2006 | 06:05 PM
crazycatholic's Avatar
mine's an '06 5-speed... i've been to 6500... it gets alittle shaky after that so i don't do that too often
Old Dec 4, 2006 | 12:33 AM
kikcaffine's Avatar
My 05 will only go to 6300
Old Dec 4, 2006 | 12:36 AM
6300 sounds about right for 05-06.
Old Dec 4, 2006 | 03:24 AM
Tcguy85's Avatar
the 07 will rev up to 6500 before the rev limiter hits. and it also "hits" differently than the prior years. it doesn't bounce quite like the rest i think it's a fuel cut instead of spark or something. it's somehow different not sure how but it is. the higher rev limit i believe should make the 07 a LITTLE quicker, you can rev each gear out a little further and also when you shift into the next gear you're at a higher rpms which should put you further in the peak powerband of the engine.
for example, i know for a fact the 07 can do 84-85mph in 3rd and people with 05-06's are saying it's impossible.
Old Dec 4, 2006 | 02:12 PM
kikcaffine's Avatar
I dont know about that. I can do about that in 3rd. Ill let you know this afternoon when I get out of class.
Old Dec 4, 2006 | 02:19 PM
emiller's Avatar
I think the 05's are closer to 81-82 before you bounce off the limiter in 3rd.
Old Dec 17, 2006 | 06:10 AM
aelements's Avatar
the manual says 77 is the max on 3rd
Old Dec 17, 2006 | 02:37 PM
emiller's Avatar
redline is around 6200 and the limiter is higher at around 6500.
Old Dec 17, 2006 | 09:05 PM
vvti24's Avatar
i've gone to 8000rpms by misshifting.. dont get a short shifter if that's too short...
yupinmytC
22
Jul 27, 2024 07:08 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
corbinortiz
Oct 2, 2015 02:45 PM
DannyBoy65
Sep 21, 2015 06:23 PM
antayala
Sep 4, 2015 05:12 PM
