2azfe engine internal ?s
hey there i was wondering a few things i cant find anywhere. I am doing a project for my automotive class and was wondering about a few things. if anyone can help i would highly appreciate it. what i need is
stock headgasket thickness
deck height
combustion chamber volume
piston relief volume
i have searched for the rest of the stuff just need these few ?s answered. thanks.
also does anyone know where to find info on our tranny? gear ratios per gear ?
deck height
There's some gear ratio info here: https://www.scionlife.com/forums/viewtopic.php?t=35024
5MT:
1st 3.538
2nd 2.045
3rd 1.333
4th 0.972
5th 0.775
Reverse 3.583
Final Drive 4.235
4AT:
1st 3.943
2nd 2.197
3rd 1.413
4th 1.020
Reverse 3.145
Final Drive 2.740
5MT:
1st 3.538
2nd 2.045
3rd 1.333
4th 0.972
5th 0.775
Reverse 3.583
Final Drive 4.235
4AT:
1st 3.943
2nd 2.197
3rd 1.413
4th 1.020
Reverse 3.145
Final Drive 2.740
Hope this helps a little
Engine
2362 cm3 (144.2 in3)
88.5mm bore x 96.0 mm stroke (3.48" x 3.78")
Compression ratio 9.61:1
Standard compression pressure 1,300 Kpa (189 PSI)
Minimum pressure 1,000 Kpa (145 PSI)
Standard diffrence between each cylinder 100Kpa (14 PSI)
From BC 2AZFE (Scion TC) Stock 248/240 212/200 .385"/.355"
Engine
my06tc
Jun 25, 2015 12:18 AM
randompacking
Jan 28, 2015 11:43 AM
umnitza
Dec 1, 2014 06:26 PM
