Bigger fuel injectors
Old 05-16-2018, 05:30 PM
Kait08's Avatar
Default Bigger fuel injectors
I'm trying to get some idea on fuel injectors, i have a 2005 tC stock motor with some bolt on wanted to know, what size CC are the stock fuel injectors,
What's the max I can upgrade to without going force induction, and would I need to upgrade fuel pump, and would I need to get a ECU tuned for it?
Kait08 is offline
Old 05-21-2018, 05:26 PM
Y2KG20's Avatar
I flow tested my injectors and they come out to 352cc @ 3 bar FP. I doubt you will need more injector for little bolt on stuff. If you go NA built engine with crazy cams then you'll probably start to need injectors. Anytime you change injector types you will have to tune somehow for the fueling change. On these cars a simple AEM FIC will do the job to get the fuel dialed in.
Y2KG20 is offline
RSracer
06-07-2011 07:16 PM
SoccerBoy_AP
27
05-22-2010 02:07 AM
318_tC
35
05-31-2007 08:00 PM
speddlysmitt
11-26-2005 10:02 AM
joeypoey5000
11-01-2005 10:43 PM
Quick Reply: Bigger fuel injectors
