CEL...
Old Mar 5, 2008 | 10:40 PM
tCmaniak's Avatar
Default CEL...
question.
Since I do have an aftermarket header...I hear about everyone going out of their way to get ridda that CEL...
Now is the CEL just an annoying light that comes on because the car doesnt recognize no cat? or is it really something you need to get rid of? if so why?
sorry if this is a noob question
Old Mar 5, 2008 | 10:45 PM
hawgs74's Avatar
you need to get rid of it...
Old Mar 5, 2008 | 10:52 PM
bBlover's Avatar
It comes on if you replace the stock airbox too. So just reset it and it shouldn't come back.
Old Mar 5, 2008 | 10:57 PM
hawgs74's Avatar
Not true -- it comes on because the 02 sensor on the down-pipe is reading higher volumes of air -- You need an antifouler.
Air box = Intake
Headers = Exhaust
Not the same systems.
Old Mar 5, 2008 | 11:48 PM
SquallLHeart's Avatar
^^ yeah.. the only time a CEL will turn on when you mess with your intake... is if you MESS up...
resetting it without fixing the problem will ensure it coming back.
Old Mar 5, 2008 | 11:49 PM
coryjames's Avatar
just get the weapon r cel fix its worth the money and always works i have 1000miles of no cell on my new xb
Old Mar 5, 2008 | 11:57 PM
tCmaniak's Avatar
ok cool but why exactly do I NEED to get rid of it. I dont mind the light but if its affecting something then ya I will fix it
Old Mar 6, 2008 | 12:46 AM
hawgs74's Avatar
how about your gas mileage -- that lights here for a reason
Old Mar 6, 2008 | 12:52 AM
coryjames's Avatar
get the weapon r cell fix its only like 35 bucks and well worth it
Old Mar 6, 2008 | 06:25 AM
bBlover's Avatar
ok dont listen to me i was proven wrong. and i didnt say they were the same system.
Old Mar 6, 2008 | 04:14 PM
tCmaniak's Avatar
ahhhhh it kills gas eh?
Old Mar 8, 2008 | 05:09 AM
SilverScion007's Avatar
I have a custom intake SR, DC HEADER 4-1,BUDDY CLUB axleback. Having a anti-fouler on the 2 o2 sensor I still get CEL Here and there. I re-checked every thing. help me please
Old Mar 10, 2008 | 12:40 AM
jamie1tc's Avatar
Default cel fix
I have been reading all ur posts since i installed my DME header. All the tips n triks to eliminate cel, even bought an anti fouler for 50bucks and still a cel, so WHATEVER! How many times can i go under the car? Ill sell the DME header n buy a TRD. That should fix it.
Old Mar 10, 2008 | 12:57 AM
op07tc's Avatar
When did TRD come out with a header? That's news to me. Anyways, there's a thread on here about a guy cutting out part of a soda can and using it along with the anti-fouler method. There's also a thread that explains that in detail. I have the DME header and used the anti-fouler mod and never had a CEL. If that didn't work, I was gonna bite the bullet and get the WR CEL Eliminator, and go against my bad feelings about them (I have their intake and I hate it). But yeah try the anti-fouler mod. If you do it right, it will work.
Old Mar 10, 2008 | 01:10 AM
draxcaliber's Avatar
okay...you guys seem kinda clueless...
okay, your stock exhaust has in this order, a primary o2 sensor, a catalytic convertor, and a secondary o2 sensor in the s-pipe.
the primary 02 sensor measures a/f ratios and makes corrections to the engine timing.
then, the secondary o2 sensor reads the exhaust emissions after the catalytic convertor so see if the catalytic convertor is doing its job.
now, when you replace your header, you won't have a cat, and if your secondary o2 sensor will let you know with a CEL.
this has ABSOLUTELY ZERO EFFECT ON YOUR MPG because the engine has already done its job mixing the air and fuel, and igniting.
HOWEVER, if you damage the primary o2 sensor during removal and reinstallation of the the header, and it can no longer do its job, reading the a/f ratios, this too will cause a CEL, but this will result in your tc going into "limp mode", where it will run really rich, adding alot of fuel to make sure you don't detonate. this is what will cause you to get a CEL, and terrible gas mileage.
Old Mar 11, 2008 | 02:49 AM
BlckdOutTC's Avatar
^^x2
Old Mar 11, 2008 | 02:51 AM
BlckdOutTC's Avatar
and i mean you dont technically HAVE to remove the light but if something else were to go wrong that would set this light off, you wouldnt know because it's already on
athlete3232
24
Nov 25, 2008 10:47 PM
jonathan110987
21
Oct 27, 2008 12:15 AM
anurok
62
Jan 8, 2008 06:09 AM
fl1p_tc
Jul 18, 2007 12:28 PM
07_nB_tC_vvti
Jun 15, 2007 12:51 AM
