chiped' ECU and NOS??? is that ok
ok so i have kn cold air, DC headers, and full cat back.
i checked with JET and i want to get my ECU chiped from them. but
after that can i still run a small 50 shot???....any knowledge would help on
putting these two together.
NOS is a brand... it's N2O or Nitrous Oxide (Short - Nitrous)
Here's the Zex info....
If you want to go N2O, and want to tune more HP as well, your best to go to one of the engine management options....
AND PLEASE... Do an insane amount of research before jumping into N2O.... it's not always the best option for a basic tuner... and it's pretty dang expensive to do right as well.... Trust me.... I know... $$$$
Originally Posted by ZEX
"Unless provisions for retarding the ignition timing have been made, ensure that an aftermarket "Chip" or a modified engine computer are NOT installed when using the ZEX nitrous system. Most modified "Chips" use advanced ingnition curves . These advanced ingnition curves can lead to detonation and severe engine damage when used with nitrous. If nitrous will be used with an aftermarket "Chip", it will be neccesary to install an ignition system that allows the timing to be retarded when the nitrous system is in use. In these instances, it is recomended that you retard the ignition timing 2 degrees for every 50 hp of nitrous use."
Not really. Retarding past zero will cause excessive heat, and glowing headers...(Never done that before
) But tooooo much timing advance will cause detonation.
http://www.gmhightechperformance.com...0211gmhtp_nos/
^ Thanks... Half the reason I'm doing this is to be able to support guys on doing it right...
I try diligently to help out as many guys on here as I can... This just allows me one more direction to assist with...
If you want to blow your engine then spray with the ECU chipped. All the JET chip does is advances the timing and adjusts the fuel curve for more power. Nitrous + advanced timing = detenation. Most stock computer retard the timing and add additional fuel at wot which is exactly what you want with N2O.
drgonzo92
14
Apr 24, 2019 07:27 PM
xjleitex15
Aug 18, 2015 01:23 AM
