Clutchmasters stage 4 or any stage 4 issues?
Originally Posted by xceptionalauto
It is normal to have a little more vibration from the clutch over stock. Did you get the sprung or unsprung? Did they resurface flywheel when clutch was replaced? If not that will cause more vibration. Is the noise or feel more like a chatter? The throw out bearing can not cause a vibration unless installed improperly and would be very noisy. The disc would only go in one way or the hub will drag on bolts
The throwout bearing is a lil different in size compared to stock and it has different clips but it fits the clutch fork. The clutch does have a very similar flywheel and pressure plate side which concerns me if its installed wrong, but I dont hear noise when im already cruising.
carid
Mar 30, 2015 07:08 AM
BrokenTC2
Jan 27, 2015 03:32 AM
Xaphoon
Jan 17, 2015 02:12 AM
peppy
31
Feb 26, 2004 03:40 AM
