Cold starts
Old Sep 26, 2006 | 03:18 PM
Tenax1970's Avatar
Default Cold starts
My 2006 tC seems to struggle with starting as the weather begins to colder. I'm worried when full blwon winter sets in will this car start? Has anyone had issues with slow/difficult starts with their tC when it's cold?
Old Sep 26, 2006 | 03:21 PM
tC4italy's Avatar
Nope...I also have an 06 and she starts up just fine, when winter hits MD/VA area I just wait a couple minutes between start up and actually movin the car
you should be fine
Old Sep 26, 2006 | 03:50 PM
senseiturtle's Avatar
Default Re: Cold starts
When I purchased my tC, it seemed to not want to start immediatley when the weather's cold. It'll start just fine... It's a f'ing toyota!
Old Sep 26, 2006 | 03:58 PM
SSQ's Avatar
SSQ
My 06 used to have random starting hesitations. It's much better now. It should work itself out as you get some miles on it. And I find it also helps if you use regular gas.
Old Sep 26, 2006 | 04:03 PM
Kendezzy's Avatar
ScionERA
Dont have that problem here.....lol!
Old Sep 26, 2006 | 04:14 PM
web's Avatar
web
I also have the slight hesitance, but just let it sit after it's started and warm for about 3-5 minutes. That should be plenty to get the oil flowing. I use 0W/30 and it's a bit easier than when I first got it. Don't pump the pedal thinking it will help. That's only on carberated cars, not Fuel injected ones. Just a little tip.
Old Sep 26, 2006 | 04:15 PM
locondcoco's Avatar
mine has "trouble" sometimes. even in not that cool weather. it'll struggle, but it will always turn over....not sure what exactly could be the cause tho.
Old Sep 26, 2006 | 04:19 PM
web's Avatar
web
Yeah, mine's warm or cold weather also. It's probobly got a low torque starter on it or there's a low current running to the factory starter not giving it the full amount of power it would need right from the start. The starter relay could have something to do with this, but it's nothing to worry about.
Old Sep 26, 2006 | 07:07 PM
scionicboom's Avatar
I have problems in the hot and cold. A lot of times if I don't let it crank long enough, I can't start it. I have to take the key out and wait for about 30 seconds and try again.
Old Sep 26, 2006 | 07:23 PM
bronxblaza117's Avatar
tC squad
it might also depend wat octane ur running, if its higher then its "harder" for the car to start...
Old Sep 26, 2006 | 07:29 PM
web's Avatar
web
Not sure about that though. The initial start is coming from the battery rather than the fuel pump. The injectors don't begin spraying until the first motion of the crank/rods/piston/cam and that doesn't start until the starter kicks the flywheel over, which doesn't start until the battery power is delivered to it. I really think it's something to do with the power deliver from the ignition switch to the starter via the relay. Might have too much of a restriction.
Old Sep 26, 2006 | 07:58 PM
engifineer's Avatar
If it is cranking slow and sluggish, it is related to the electrical side (starter, etc). If it cranks fine but does not start, it is in the realm of ignition, fuel, etc. I have never seen a toyota that starts on the first crank in the cold. But I have also rarely seen them totally fail to start. Dont worry if it cranks a couple of times before starting. That is just toyota. If it cranks very slow or has a hard time cranking over, you need to check your charging system first (a quick check is to make sure it is producing approx 14.5 V while running) and then your battery.
Old Sep 26, 2006 | 07:59 PM
web's Avatar
web
Thanks for jumping in.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
hampton1100
May 28, 2015 07:32 AM
mw1957
Mar 16, 2015 06:00 PM
CPL_Radar
Mar 5, 2015 05:42 AM
cid_mcdp
Jan 5, 2015 02:45 PM
