a couple of questions...
Old Apr 9, 2005 | 04:36 AM
kutsuju_dj's Avatar
Default a couple of questions...
i just installed my intake and love it....... I would like to know however if any of yall are getting a whistling sound while driving from the intake... i never had that on my civic with my aem... just wondering if that is normal for K&N or if i may have a air leak.......
also my windows dont work now, how the hell do i fix that
Also i miss shifted bad tonight going from third to fourth instead i went third to second...... has anyone bent a valve doing this..........
Old Apr 9, 2005 | 04:41 AM
taek's Avatar
yur windows dont work?! what the hek?
bent a valve mis shifting?! what the hek
how the hek do yu drive?!!?!
Old Apr 9, 2005 | 04:44 AM
tCholleration's Avatar
you might have to reset your windows. check your manual. there's instructions on doing so.
Old Apr 9, 2005 | 05:15 AM
TheQuietThings's Avatar
disconnect the battery for 30mins. reconnect and start the car, let it run idle for 10-15mins. then hold your power window buttons up for a few seconds, and then close them, repeat this and it should start working. im not sure if thats how the tC works, but i know thats how my 93 altima works lol. sorry if it doesnt help. worth a shot though.
as for the intake, make sure everything is connected properly and if it is, then i wouldnt worry too much about it, every car sounds different, hope this helps.
Old Apr 9, 2005 | 09:30 AM
LIKE_OR_AS_GOD's Avatar
I think they tell you how to do it in one of the walk throughes for the intake. I remember doing just that, run them up and down. Have to reset the roof too. That one was a little more tricky, just hold the button down closed for a bit and it reset. Atleast I think that is how it worked. I was doing several things at once when I reset them.
As for the whistle, might help if you say what type of intake. I get a WOOSH (sucking sound) when I hit around 4K RMP, but no whistle. If it while your idle? Than check your fittings, while driveing might still check them. It's allways good to go back and retighten things after a little break in too.
yupinmytC
22
Jul 27, 2024 07:08 PM
steeze69
May 24, 2021 02:57 AM
Blunderbuss
Oct 8, 2015 04:56 PM
olyellr
Sep 28, 2015 10:32 PM
