e manage and cam com
Old Jul 6, 2007 | 07:47 PM
equinox2355's Avatar
Originally Posted by Matt_Burgess
So is doing the TRD thermostat worth it? I know every little bit helps, and a colder denser air charge will create horsepower even if its 2-4 hp its worth it to me..
the thermostat has nothing to do with the air charge.
Old Jul 6, 2007 | 07:56 PM
Matt_Burgess's Avatar
It changes the cylinder temp, It lowers the temp around the air entering the cylinder witch in tern lowers the air temp..The coolant/water surrounds the cylinders in these 2.4 engines, The cooler the cylinders are the cooler the air is, its common sence.
Old Jul 7, 2007 | 02:55 AM
Heat is the enemy! Running a little cooler is good for high reving engines especially ours. When your doing 80 on the highway and your tack says 3500rpm or 120 and your at 5400- 5500 rpm's, Thats alot of heat and friction going on in the engine.. A cooler running engine is just one of the many tricks from the old V8 days that works and makes sence,, lol
yupinmytC
22
Jul 27, 2024 07:08 PM
steeze69
May 24, 2021 02:57 AM
MisterSkiz
Sep 27, 2015 10:25 PM
sccarally
Regional - Lonestar
Sep 27, 2015 09:24 PM
Topfueltom69
Sep 6, 2015 05:25 PM
