govener
Old Apr 9, 2006 | 10:20 PM
  #41
Shoelesscraig's Avatar
N.G.S.O.
Correct me if I'm wrong, but the part that cuts off car off at 127mph IS what cuts the fuel off....thats the entire reason the car can't go above 127 I believe.
Old Apr 10, 2006 | 03:15 AM
  #42
hahaitzskippy's Avatar
rev limiter cuts fuel
governor cuts fuel
rev limiter is to prevent OVERREVING (of course you knew that)
governor cuts fuel to prevent OVERSPEEDING (hence 5.9 rpm in 5th gear at 127mph)
so ya...
Old Apr 10, 2006 | 03:28 AM
  #43
06scionsc's Avatar
Not here to bash anyone, just wanted to make a quick statement. If you wish to remove the speed limiter and fuel cutoff and have a car that is capable of going above the factory set numbers good for you, however the rev limiter is not something I personally would remove or change as tc's have a somewhat long stroke and I am sure toyota did not design the rods or bearing to withstand a higher rev. Just my opinion and in no way am I advocating street racing. I am a big fan of legal strip racing the scca, nhra, and idra.
Old Apr 10, 2006 | 11:43 AM
  #44
PghtC's Avatar
not to mention the suspension is not designed to be stable at those speeds. You better build the car right if you want to go that fast.
Old Apr 10, 2006 | 11:57 AM
  #45
DouBLeJ16's Avatar
Originally Posted by PghtC
and even my baby
man that ____es me off. You would put your baby at risk?
This post should be locked.
I hope you're joking and you really aren't THAT dumb.
Old Apr 10, 2006 | 11:59 AM
  #46
DouBLeJ16's Avatar
Originally Posted by AROQ
The rev limiter on a car is there to prevent over-reving, which will destroy the engine. Most gasoline cars designed for street use have a limiter somewhere around 6000-7000 RPM. Some sports cars have it set slightly higher to allow the engine to make more power in the high RPMs.
Simply removing the rev limiter, without making any other modifications to a car, will do next to nothing. In some cases, being able to rev the engine higher will yield slightly better performance, often at the cost of more engine wear.
You should only worry about raising the rev limiter once you've done substantial work to the engine. My personal advice would be to have at least the full exhaust upgraded (including the exhaust manifold and downpipe), a sport camshaft and some way to get more fuel to the engine.
The stock exhaust really restricts everything, so don't even think about removing the rev limiter if you're still running the stock exhaust. The stock camshaft is designed to make power in the stock rev range, so there really isn't any reason to raise the rev limiter if you still have the stock camshaft installed. About the only reason I see to raise it when you're still running with the stock camshaft would be so you don't accidentally hit it (when, driving competitively on the street, or in another similar situation). Once you install a sport camshaft you will want to raise the rev limiter so you can use the power the camshaft makes above 6000 RPM. You should also give the engine some more fuel and richen up the mixture a bit if running a sport camshaft, and if running in the high RPMs.
Unless you build an all-out race car, you will not be reving past 7000-8000 RPM. Any car that makes good power above 7000 makes little power below 4000-5000 RPM, and is not by any means a street car.
Thanks for posting something useful. Everything else in this thread should be deleted, it is completely off topic.
Old Apr 10, 2006 | 03:39 PM
  #47
Jamia's Avatar
Well I'll tell you this much. Most of the people who know enough about cars to be able to remove the speed limiter will not tell you how to do it.. This is because they want to know who they are talking to and make sure that person should be removeing it.
For example a 16 year old kid has no right to remove it without his parents knowing. Even if he only races on a track.
To argue if its right or wrong to speed on the streets will not get anyone anywhere. Altho I have seen something like this coment on other sites this one seams best fit.
Argueing on the internet is like street raceing. Even if you win your still retarded.
Old Apr 10, 2006 | 04:03 PM
  #48
N.G.S.O.
Nicely put and oh so true!!
Old Apr 10, 2006 | 05:12 PM
  #49
JonDaddy82's Avatar
Well, for those of you of are not involved in the internet top speed ____ing match, here is my DIY write up of how to install the GReddy speed cut controller. The write up is for a Corolla of course, but could easily be done on a TC if you have the ECU chart for it. I got mine from PTUNING.COM for around $70 shipped.
Old Apr 10, 2006 | 06:08 PM
  #50
engifineer's Avatar
That is correct, but again I point out that the speed limiter does not equal the rev limiter. Two different systems. They did not use the rev limiter to limit the speed of the car. You can raise the rev limiter and still not pass 127 mph
******EDIT***********
Oops, see someone else already brought that one up
Old Apr 14, 2006 | 07:17 PM
  #51
surfripcurl's Avatar
DelMarVa
<<<<<<<HAS BEEN 138 in the TC That is where my car shut off... REALLY STUPID THING TO BE DOING ON THE HIGHWAYS BY THE WAY
Old Oct 3, 2006 | 05:27 PM
  #52
sciontc_06's Avatar
removing it is worthless.. not really a lot of power to make that high up in the rpms for a tc.
Old Oct 4, 2006 | 02:02 PM
  #53
THansenite's Avatar
Ummm, no you haven't. Not unless you got a super special edition tC that came from the factory with a different ECU. If your spedometer said 138 when your car cut out, you need to get it recalibrated.
Originally Posted by Shogun
If you have your car upgraded to the point where you need to get rid of the limiter, you should be abe to figure it out for yourself by then.
Best advice in this thread.
Soulbringer
Jul 16, 2004 01:39 PM
dirtysocks
Jul 13, 2004 11:02 AM
