Ingalls "stiffy" ETD trouble
Old Jan 11, 2010 | 11:30 PM
AngHellicTc's Avatar
Default Ingalls "stiffy" ETD trouble
So I installed the ETD this afternoon, everything is installed correctly. I have this rubbing/vibrating sound that is beyond loud inside the car, that i cannot get rid of. I have tried everything. I added rubber washers, switched around the order of bolts/nuts and such, added dynamat between the bracket and frame of car.. I was able to dampen the sound slightly, but it is still obnoxious, and don't want to drive with it. I have looked at both threads related to the install and noises of this ETD, but nothing has worked.
As of right now, my order of install goes:
bolt
bracket
rubber washer
metal washer
O-ring
Damper
Nut
BUT i still have this noise. It sounds like a mix between vibrating and rubbing, but nothing is touching the brackets or dampers that shouldn't be. The black hose is zip tied out of the way, I'm clueless.
SOMEONE HELP.
Old Jan 12, 2010 | 01:13 AM
cburglb34's Avatar
its just how etd is man its not as bad if u set the stiffness on the lowest setting
Old Jan 12, 2010 | 01:28 AM
SquallLHeart's Avatar
it's what it does. if you don't like it, uninstall it.
otherwise, get used to it.
Old Jan 12, 2010 | 01:29 AM
damn. alright. thanks anyways
Old Jan 12, 2010 | 01:33 AM
there's only so much dampening you can do to reduce it, but it's not gonna go completely away.
now if it's like metal rattling against each other.. you might wanna look over the install again.
Old Jan 12, 2010 | 02:22 AM
rangerryda's Avatar
Mine sounded like that too... for the whole 2 hours I used it. Sold it and bought motor mounts. Best idea ever.
Old Jan 12, 2010 | 04:06 AM
user 7208230's Avatar
Also make sure that you did the proper preperation with the ETD, there was this odd break in/orientation process that I saw, I'll try to think where I saw it. Don't think it will take away all the noise but it might help, who knows.
Old Jan 12, 2010 | 05:13 PM
06sciontcnda704's Avatar
http://www.dezod.com/cat_motor.cfm
Old Jan 13, 2010 | 03:59 AM
aren't new motor mounts a BFD? like taking the engine out and all that?
Old Jan 13, 2010 | 02:04 PM
paul_dezod's Avatar
Scionetics
KAD
Originally Posted by 06sciontcnda704
Motor mounts may cause some more in cabin vibrations if you are real sensitive to these types of things. So it may not be the best for you. However, the upside to them are that they greatly reduce squat, wheel hop and improve shift stability when power shifting.
Old Jan 13, 2010 | 04:26 PM
rangerryda's Avatar
No the motor doesn't have to come out lol. You have to take the battery out for one of them and lower the subframe for the rear one. The front one is stupid easy. I'll admit, if you don't have the right tools, they are a PITA but if you have a proper shop, they really are not that big a deal.
Old Feb 3, 2010 | 12:04 AM
bdyer666's Avatar
yeah i did mounts and torque damper im taking mine off cause the mounts did a world better job with getting the torque to the wheels the damper is more for looks but does do a lil bit plu if u listen real well u can hear all the engine internals in the cockpit cause of it and people think your car is ticking
07tcscion
Oct 8, 2015 05:42 PM
DannyBoy65
Sep 21, 2015 06:23 PM
Chrono
Aug 25, 2015 05:59 PM
iFangy
Aug 13, 2015 05:10 AM
domincnTC
Aug 4, 2015 01:47 PM
