installing INJEN CAI
Old Aug 5, 2007 | 07:36 PM
  #201
ScionTc59's Avatar
Default Injen CAI and other mods questions
Doesn't it have a great sound? I thought so too. And when I put on my Dynaflow cat back exhaust next week, it should roar! Hope it's not illegally loud however. I don't know how the dealer put my intake on as to not to scratch it, but they managed ok. I did notice that one of my wheels has a divet in it, not by my hand either, so the next time I visit the dealer, I am going to ask for a new wheel. I am in the market for a digital camera (yes, I am still in the stone age in some respects), and as soon as I get it, I will be able to post pics of my ride. I want to get that new camera that has a USB cord and port and you can just download your pics by plugging it into the computer! It's a newer model, I think it's a Sony. Cheers to you all! Oh, and if anyone out there knows of more mods that are fairly inexpensive, legal, won't void my warranty, and will boost hp/tq, I am open to all suggestions and would greatly appreciate them. Thanks!
Old Aug 6, 2007 | 03:50 AM
  #202
GammaTNT's Avatar
Originally Posted by ScionTc59
The Injen, as far as I know, is an oiless filter
K&N and Injen cleaning kit both come with oil.
http://www.injen.com/docs/products/listing.asp?pcc=ol
Old Aug 10, 2007 | 07:28 PM
  #203
ScionTc59's Avatar
Default Magnaflow on, now I need a header!
Well, the Magnaflow exhaust (I thought it was a Dynaflow but it's not) went on without a hitch, though I had to take it to Midas to do it; the dealer had no cutting tools and the install requires you cut the pipe 3 1/2" aft of the 2nd cat. So I took it to Midas and 1/2 hr and $45 later, it was on! So I save a big chunk of change in the process as well! Now my question is: where can I get a LEGAL header that is bolt on and does not eliminate the cat(s)? New Edge has one, but it's off road use only because it does away with the 2nd cat. Any help would be appreciated! Thanks much!
Old Dec 8, 2007 | 06:19 AM
  #204
bsp_in_sc's Avatar
dude, i couldnt get the second pipe in, but i did leave it as short ram intake... what kind of noise should i hear, and how can i make sure i have no leaks, i tightened everything real tight...
kind a sound i hear is like a roar, kinda raspy, but i dont know i think im just worried i did somthing wrong...
someone tell me what to do or if i did something wrong
Old Dec 8, 2007 | 06:21 AM
  #205
bsp_in_sc's Avatar
one more thing its 2:20am in the morning... didnt take my bumper off either i think thats why i could get it in, i just dont know how to, im going to take the bumper off tomorrow.
Old Dec 8, 2007 | 06:32 AM
  #206
mengsta's Avatar
Yeah you should take the bumper off to install the CAI portion. very easy to take off. Itz on this forum sumwhere too.
Old Dec 8, 2007 | 06:35 AM
  #207
bsp_in_sc's Avatar
mengsta, is this growl normal... how do i know i dont have any leaks, and besides leaks is there anything else i could have done wrong??/
Old Dec 8, 2007 | 04:17 PM
  #208
mengsta's Avatar
Yeah a growl is normal, Kinda weird. You talking about the growl when you let off the gas? It shouldnt be raspy but yeah the growl is normal. Well you shouldnt have any leaks especially if you have it as a short ram right now, itz pretty simple. Well you said you tightened everything so tahts good. You ressetted the ecu right? and no CEL light. Then you should be fine. Well if you are really wrrd, If you turn on the car you can actually feel the intake sucking air with just yur hand over the filter. atleast i could with my weapon-r. But yeah you cant have any leaks if the piping is fully in the rubber couplers and you tightened it. unless you have a hole sumwhere.
Old Dec 8, 2007 | 05:09 PM
  #209
bsp_in_sc's Avatar
i guess i reseted it how do you reset it?
Old Dec 8, 2007 | 06:54 PM
  #210
Matt_Burgess's Avatar
You just take the ground wire off your battery for 5 minutes and then reconnect it.
Old Dec 8, 2007 | 09:05 PM
  #211
ScionTc59's Avatar
Default Injen CAI
You can use it as a short ram intake, adding the downpipe is not necessary plus I believe you will get a freer flow. I did it and it works great.
Old Dec 9, 2007 | 05:54 AM
  #212
jamessicat25's Avatar
short vs cai? pros con?
Old Dec 9, 2007 | 07:17 PM
  #213
beedee's Avatar
short pulls warmer air, cai pulls 'cooler' air....go cai.
Old Dec 9, 2007 | 09:03 PM
  #214
I think someone dyno'd it some where. I think there was a 3 horse power differance, that and the cold air setup is more efficient cause the air goes smoother through the pipe past the mass air flow sensor.
Old Dec 10, 2007 | 12:58 AM
  #215
mengsta's Avatar
Yeah and theres a whole bunch of threads on pros vs cons. Search alot, youll get used to the forum.
Old Dec 10, 2007 | 01:15 AM
  #216
man i went with short.. and the filter is like hitting my fender.. sounds like if it rained.. it would pour on the filter
Old Dec 10, 2007 | 01:27 AM
  #217
jakedudeta's Avatar
Noticed something about the pix that was new to me. Ive read/seen posts that depict the filter rubbing if the injen is in sri mode, the pic in the original post looked like it would clear? Is it a newer version or something?
Either way, great post.
Old Dec 10, 2007 | 01:39 AM
  #218
mengsta's Avatar
Just go with a CAI, ive read problems here n there about the SR plus you paid for it, mightaswell use it fully. But theres one thing you should get for any CAI is doctorisotopes fender panel. Prevents rubbing. too lazy to check but i think itz like 15 bucks.
Old Dec 10, 2007 | 03:36 AM
  #219
look how my filter goes under the fender line.. sounds like if someone mess with me.. they could just spray water on the side
Old Apr 24, 2008 | 03:04 AM
  #220
hookedonlucy's Avatar
installed mine today. wow it was a b++ch
first of all, i dont know if its my car or the intake, but it fits like sh*t
secondly, it was almost impossible to get the 2nd pipe in without scratching it like hell unless the fender was removed
overall, it dosent fit correctly.
but it works fine and sounds awesome :]
