low idle, knocking noise from underneath
Old Jul 1, 2011 | 01:48 PM
kyrgyz's Avatar
Default low idle, knocking noise from underneath
Hey guys,
I have been trying to identify the problem for a while now.
1) low idle:
I was idling at .5 -.45 for a while, so finally got to cleaning out the throttle body- lots of crap came off it- without disconnecting the battery. Started up- idle came up to 1000 rpms, disconnected the battery for 10 mins to reset the comp- it went back to .5-.45 rps. It is not the MAF sensor as I disconnected it as well to check- it was running at .5 to .45 even without it. Some say I need to give it 100 miles before it sets to normal? What do you say
2) I have a weird noice coming from underneath the engine only when accelerating on 2000-3000 rpms. The noice is most obvious on regular gasoline (I'm not joking) , premium still does it but much less. It also seems as if it becomes obvious once the car is running hot.
I got an '05 tc with 132k.
CAI
Axle Back
I would appreciate any suggestions!!!
Thank you
Old Jul 1, 2011 | 04:01 PM
kyrgyz's Avatar
anyone?
Old Jul 1, 2011 | 05:38 PM
sciontc_mich's Avatar
Originally Posted by kyrgyz
anyone?
with that many miles on the engine, have you taken out the spark plugs and replaced them?
what kind of noise is it making? clanking? pinging? clunk? scraping? banging? try and describe the noise.
Old Jul 1, 2011 | 05:53 PM
kyrgyz's Avatar
yes spark plugs changed every 20k miles, just changed these 10k ago.
The noise is very metalic, when you drive along a wall you can hear it especially loudly. I have no idea how to describe it- maybe I'll try to record it and post it here. I heard it on other cars too but cannot figure out what it is.
I'll post it here once i have it
Old Jul 1, 2011 | 05:58 PM
hmmm.. exhaust issue? definitely try and find out the location of the noise, that always helps.. starting to wonder if it's a catalytic going bad. we have two of them. the 2nd one isn't really monitored by anything, if it was clogged, that could cause the issue too, that you're describing.
Old Jul 5, 2011 | 02:29 PM
typerhedlights's Avatar
these engines are noisy as hell. i would suggest finding another tC of similar year and listening to their engine. More then likely, it sounds the same as yours and your chasing your tail.
Old Jul 5, 2011 | 08:36 PM
kyrgyz's Avatar
grrr, ye I'll start changing the exhaust from the muffler up, it seemed like the noise was actually coming from the muffler, but I'll see.
Anyone on the idle issue? After 150 miles of reset still idling at 450-500
Thanks
Old Jul 6, 2011 | 05:36 PM
kyrgyz's Avatar
so yesterday I got in, changed the air filter,cleaned the MAF sensor, reset the ECU- still idling at 450-500, someone HELP!
Old Jul 7, 2011 | 01:17 PM
kyrgyz's Avatar
Also, rolling at 70 miles on neutral gives me the idle of 750- what i am looking for
Old Jul 22, 2011 | 06:44 PM
Im2c0oL's Avatar
it doesn't give you and engine code? it would be helpful...
D_Roke
Mar 31, 2015 05:37 PM
evolving_machine
Jan 13, 2015 08:04 PM
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
eric_m
79
Mar 17, 2013 12:21 AM
