Megan Header installed, I have some problems/question.
Old May 2, 2005 | 02:24 PM
  #81
toastbox's Avatar
Originally Posted by Stu Gotti
I just put my headers on the other night.. so far probally like a little over 500 miles or so, and no problems.. I've been racing the hell out of it.. and it sounds great, and def a power increase. I guess the inevitable is bound to happen soon then.. oh well.
"Header"....there's only one on a 4banger I'm still jealous tho
Old May 2, 2005 | 03:49 PM
  #82
Stu_Gotti's Avatar
JK JK.. I know.. I just say headers... just cause that's how it comes out.. I try not to hurt my head being technical too much!
Old May 2, 2005 | 03:58 PM
  #83
toastbox's Avatar
Old May 2, 2005 | 06:20 PM
  #84
Giravani's Avatar
Originally Posted by English
that your cat isn't working, time for spark plug anti fouler trick
Have you not been reading this thread at all? We DID do the antifouler trick, and we did it correctly as well. I'm really curious now to whether or not the debris from the header broke our secondary O2 sensors. If that's the case, I smell a lawsuit.
Old May 2, 2005 | 06:39 PM
  #85
Stu_Gotti's Avatar
Old May 2, 2005 | 07:14 PM
  #86
toastbox's Avatar
I'm not sure how it would break the 02 sensor, but i suppose it *is* possible for a peice of the cat to end up in the cavity the sensor is reading from. If that's the case, I could see a CEL being thrown maybe, as the O2 will be reading false values, well below the normal threshold. Again, this is all speculation.
Old May 2, 2005 | 11:08 PM
  #87
DouBLeJ16's Avatar
I find it odd how I can go 70-90 miles with no CEL, then all of a sudden it comes back.. and it's always the same code.
I just found out yesterday you can clear the CEL without disconnecting the battery..
just hold down the tripometer reset button while your car is in ACC mode (not started).
keep holding the button while you start the car and it turns right off.
I haven't actually tired this yet because it hasn't been on for very long. when it comes back on I'll let everyone know if it works.
Old May 2, 2005 | 11:25 PM
  #88
Giravani's Avatar
That is a reset for for the "Main Req." light that the dealership does after completing their maintainence. I had to ask the dealer how to do this after changing out my oil and doing the usual scheduled stuff by myself. I don't think it will reset the CEL, but I'll give it a shot when I leave work in a half hour or so.
Old May 3, 2005 | 08:11 AM
  #89
DouBLeJ16's Avatar
I've gone 140 miles with no CEL.. <knocks on wood>
Old May 3, 2005 | 12:29 PM
  #90
Stu_Gotti's Avatar
I'm just letting mine stay on.. screw it.. I'll wait until one of you genius's figure out the cure.. I cant see having to reset that damn thing every 80 miles or so...
Old May 3, 2005 | 12:54 PM
  #91
DouBLeJ16's Avatar
Does yours only come on every 80 (give or take a few) miles also?
Old May 3, 2005 | 01:46 PM
  #92
falcon9094's Avatar
mine comes on like 10 mins after I reset it at idle
Old May 3, 2005 | 04:53 PM
  #93
Giravani's Avatar
Yeah it's about 60-80 miles for me too.
Old May 3, 2005 | 05:53 PM
  #94
Stu_Gotti's Avatar
Hmm.. I dont know.. It wasn't on at first.. then it came on.. now its on, and i'm just leaving it on..
Old May 3, 2005 | 06:12 PM
  #95
Giravani's Avatar
That's what I've been doing. I've been using my roommates OBDII utility for a while now. It clips right into the ECU data port and flashes the code for the CEL on a simple LCD display, and after a couple cycles it will eventually just delete the code. I have more peace of mind having the reader constantly plugged in so I'm not inadvertantly ignoring a much more serious problem.
Old May 5, 2005 | 06:59 AM
  #96
DouBLeJ16's Avatar
180 miles and no CEL, maybe it's gone for ever?
will it return?
stay tuned!
Old May 5, 2005 | 11:58 AM
  #97
Stu_Gotti's Avatar
Ok ok.. maybe I'll try and reset it, does anyone know how to? Thanks ya!
Old May 5, 2005 | 11:25 PM
  #98
DouBLeJ16's Avatar
just disconnected the negative battery terminal for about 10 minutes, then connect it again.
Old May 6, 2005 | 12:38 PM
  #99
Stu_Gotti's Avatar
Figured that.. Thanks bro.. I didn't know if there was a button or not.. like the low tire pressure one.
Old May 7, 2005 | 05:09 AM
  #100
Giravani's Avatar
will it return?
stay tuned!
I called Megan and here's what they told me, although it sounds like something they just pulled out of their ___. Here goes:
The secondary O2 sensor gets triggered because the exhaust gasses get superheated in the precat due to the bottleneck from the 4-1 convergence there. The exhaust gets so hot that it destroys the ceramic material in the precat which is what accounts for the chunks in the exhaust that DoubleJ16 and I are both experiencing. This is all because of quick engineering, cheap parts, and the desire to be competitive in the aftermarket world. Well, that's great, so now we have headers that fart fire. Lovely.
I'm taking these things out before anything else happens. Back to stock for sure. I'm so tired of all these issues with these things.
Be careful guys, these things get WAY TOO HOT and could be SERIOUSLY DANGEROUS, and MAY CAUSE OTHER PROBLEMS TO YOUR EXHAUST.
This could be the same reason why our secondary sensors are getting triggered. The exhaust is practically VOLCANO hot!
