Need help diagnosing Start-Up problem
Old Jun 17, 2014 | 11:04 PM
NJ_tC's Avatar
Default Need help diagnosing Start-Up problem
Posted this over at ClubScion and havent found a solution. Check out the video so you can hear it struggling/choking on start up
http://tinypic.com/r/5da3o3/8
it happens every single morning after sitting over night and that's the ONLY time it happens. Here's what I know is fine:
Spark plugs, battery, MAF, Throttle Body, Air Filter.
So what could be causing this rough start up? Fuel Pump? I dont hear it making any noise so it could be a possibility. Other than that there really arent any other problems with the car.
Old Jun 22, 2014 | 09:13 PM
That_Kid_Ju's Avatar
Injectors? Maybe a leak if you've tinkered with them before or just may not be firing. Could also be ecu problem or timing is off. Also check coil packs. Are you throwing any codes?
Old Jul 14, 2014 | 04:13 PM
Kik's Avatar
Kik
Also, pull your plugs again and look into the cylinder with a flash light. Do one of the piston tops seem to be a little cleaner than the others?
Old Aug 8, 2014 | 09:23 AM
kruso's Avatar
Check the ecu for codes and run a compression test.
tcer904
Aug 30, 2024 12:49 PM
RY_TC07
Jul 18, 2017 05:18 PM
bravosixniner
May 24, 2015 09:56 AM
ScionXa06
May 18, 2015 10:05 PM
eric_m
79
Mar 17, 2013 12:21 AM
