Need help Remove and Replace tC Engine
Old Nov 11, 2010 | 10:09 PM
TRDChargedtC's Avatar
Default Need help Remove and Replace tC Engine
im not sure if this is the right space for it.. but i need help removing my Scion tC engine and replacing it.. i need someone knowledable and is in the nc area.. close to winston salem or greensboro.. i will pay.. feed.. whatever.. i just need to get this done.. anyone free this weekend to help or anytime in the near future.. lmk...Please PM me!!
Thanks in advance
Jarek
◄◄Click Here to Add your Vehicle to Garage
What does Garage is empty, Add now mean?
Old Nov 11, 2010 | 10:22 PM
Crippie's Avatar
1UP Crew
sorry i cant help, but what happend to the motor? blown?
Old Nov 11, 2010 | 11:56 PM
yes.. just a spun bearing.. not sure why? i think it was drove hard before i bought it
Click Here
Old Nov 11, 2010 | 11:57 PM
but i purchased another engine so i can drive it and put the original motor in the shop for a nice build ;)
Click Here
Old Nov 16, 2010 | 12:09 AM
jar2709's Avatar
I can walk you through taking it out there is not much to it. Just very much time consuming.
1) Take battery out
2) Jack car up and take off the front tires.
3) Separate the Lower ball joints
4) Remove both drive shafts
5) Remove Radiator and Hoses
6) Disconnect the shifter cables from the transmission
7) Take off the exhaust manifold and the S pipe.
Disconnect vacuum lines
9) Disconnect the wire harness from the ecu and pull out the boot with wires through the firewall.
10) Double check to make sure that nothing else is connected to the rest of the car such as Wires or vacuum lines etc. If so remove them. The wire harness can stay attached to the engine because they will come out with the engine.
11) Use a cherry picker and get a short chain and find points where you want to connect a bolt though the chain onto the engine.
12) Place cherry picker in front of car and attach the chain to the cherry picker. jack up the cherry picker just enough to take off the slack in the chain.
13) Remove all the motor mounts, keeping a eye on the cherry picker make sure to jack up as much as needed to prevent the motor from sliding down.
14) once all mounts are off jack engine up and out of the car.
15) ENJOY A NICE COLD BEER.
Repeat Steps for installation!
Im not responsible for any damage or injury do too following theses steps and you should use extreme care while doing this. you use these instructions at your own risk.
Old Nov 16, 2010 | 12:33 AM
dropzone's Avatar
There are hooks that bolt to the engine to get the chain hooked on to. Last time I tried to order them the parts guy behind the counter said they were on back order, this was almost a year ago. He didn't seem like he wanted to help much. The part numbers should be posted up somewhere.
Check this link...http://www.toyodiy.com/parts/p_U_200...MGKA_1104.html
Look for the part Hanger, Engine, no. 1 and Hanger, Engine, no. 2. Take down the part numbers and order at the dealer.
Old Nov 18, 2010 | 03:51 AM
06sciontcnda704's Avatar
Good Luck at least now the blown one can get a nice build =]
Old Jun 3, 2017 | 07:04 AM
Cory1995's Avatar
Default Need help
I was wondering if you knew what tools were needed for a 07 Scion engine removal
kdepew
May 3, 2018 03:29 AM
brandilei
Jul 24, 2017 08:03 AM
xjayhx
Mar 20, 2017 06:54 PM
