Problems with injen intake
Old Oct 26, 2008 | 05:41 AM
Smooth_J's Avatar
Default Problems with injen intake
In short - how can I stop the rattling and metal on metal issues? I tried foam, neoprene, and the Doc CAI Panel - same issue. It just rattles like crazy and I tried a few times to fix it already with no success
Anyway can help please....?
Old Oct 26, 2008 | 05:44 AM
cavalierkid888's Avatar
I use the doc-I panel AND the rubber piece they give you for that spot and I get no rattles.
Old Oct 26, 2008 | 07:48 PM
Bam727272's Avatar
i used the rubber piece too and no rattles
Old Oct 26, 2008 | 07:52 PM
Smooth_J's Avatar
Hmm - I dunno then :/
I really want this thing to be fixed, but it keeps on having issues. I don't want to convert to a SRI, but if I still have problems I will have no choice. I will try the Doc and Rubber piece one more time and hope for the best.
Wish me luck!!!
Old Oct 26, 2008 | 08:11 PM
If you put in the rubber piece around that oddly shaped hole in the fender wall, and use doc I's CAI panel, I don't see how the intake could possibly rub there and make noise. Maybe it's rattling somewhere else???
Old Oct 26, 2008 | 09:04 PM
highvoltage1's Avatar
My Doc Iso CAI panel didnt really help any. But thats either the hole cutout was off or the Injen intake wasnt designed that good. i love the feel of the intake but it rubbed no matter what i did. i didnt really have a rattle but id rather have a rattle then metal on metal rubbing. I do have a little rattle now in colder weather and on acceleration but thats cause i put a rubber coupler in the 2 spots it was rubbing although they are the cheap spectre ones so they are really hard. But id rather have the rubber to metal. So i deal with it. But once i get my exhaust i wont here it. But I may get back under there and try a for more things before i give up and just allow it to rattle.
Old Oct 26, 2008 | 09:09 PM
Kanchi's Avatar
Put some foam camper tape on the inside of the fender where the intake comes in contact with the fender...seriously don't know why Injen didn't either design it better or include something in the kit to counter-act this. Every Injen CAI I have installed had this same problem....especailly 07+
Old Oct 26, 2008 | 09:11 PM
Ace83's Avatar
Ronin Scion
I too have some rattle even with the doc I, but my setup is different.. the rattle could be somewhere else
Old Oct 26, 2008 | 11:12 PM
Smooth_J's Avatar
-Repost-
Old Oct 26, 2008 | 11:13 PM
Smooth_J's Avatar
When I did my first Doc CAI setup I had issues with rubbing so I put some rubber in between the CAI and the metal and it was fine. So then I took it apart again to see how I could fix it. Turns out I couldn't and then took it out and went with neoprene and foam.
Here is a picture of what it looked like with the Doc I in place.
Please keep in mind that the drawing is not to scale, nor is the pipe - but you get the idea (I hope). The pipe is getting pushed onto the metal causing issues with rattling and worse of all...rubbing.
Full: http://farm4.static.flickr.com/3235/...e63ff999_b.jpg
Old Oct 26, 2008 | 11:36 PM
So wat exactly is your point? I am pretty sure everyoen knows how the pipe goes through the panel and the panel has the rubber strip to fit around the edges of the hole.
Old Oct 26, 2008 | 11:44 PM
Smooth_J's Avatar
If you look closer at the picture (need the full version to see it better), I am pointing out the metal on metal issue that I am having with the Doc I panel. I am trying to make one (picture) to represent what happens without it.
Even when I put a piece of rubber in between it "eats" it away and then it starts to rub again.
Old Oct 26, 2008 | 11:51 PM
Ace83's Avatar
Ronin Scion
link doesnt work! but on mine the rubber get rubbed out of place by the pipe, i might just glue that rubber permanently lol
Old Oct 26, 2008 | 11:56 PM
Smooth_J's Avatar
I am willing to try anything at this point. I recently changed the link to:
Please let me know if you still have any issues seeing it.
Old Oct 27, 2008 | 12:19 AM
I see what your talking about now. My bad. Anyways i really dont think I am having that problem where you are. I will have to look again but i didnt notice anything when i took mine out to readjust it and put the couplers on. I am having problems was having problems with mine hitting the fender and the plastic wheel well shield.
Old Oct 28, 2008 | 01:26 PM
Smooth_J's Avatar
Well, for now I took off the extension tube to make it a SRI. Once I took it off, I realized how "bad" shape the tube was in. Not only was there was the metal on metal, but the pipe was partially dented due the vibrations
Pipe in the car:
Full: http://farm4.static.flickr.com/3158/...a729da9d_b.jpg
YooItsJay
Dec 2, 2015 08:13 AM
jonny_b
Mar 9, 2015 03:40 AM
carid
Feb 9, 2015 01:49 PM
dzcustom
Nov 6, 2003 12:54 AM
arinvolvo
24
Nov 2, 2003 05:30 AM
