RASP
Old Jul 16, 2007 | 08:54 PM
  #101
tCizzler's Avatar
Here ya go. I hope it's not too bad quality. It's from my phone. It's red lining 1st and 2nd. Whatcha think?
Old Jul 16, 2007 | 08:58 PM
  #102
ashiva's Avatar
Default Re: RASP
Originally Posted by RS21128
Originally Posted by caparamedic
i hae the injen cai, and hks exhause...who thinks im gonna get rasp if i add dc's 421 headers? and how bad will it be? any suggestions...how do resonators work?
i HAVE that exact set up....with a megan mid pipe...it IS a lil raspy...once u lay on it...maybe past 3 grand...but its really not bad
liar, it's pretty bad.
Old Jul 16, 2007 | 11:42 PM
  #103
BionicJuic3's Avatar
I'm thinking of this current set-up: Megan Headers, Megan S-Pipe, Custom 2.5" Midpipe with a High Flow Cat and an Aero Resonator, into my Tsudo N1 Exhaust... What do you guys think?
Old Jul 17, 2007 | 11:53 PM
  #104
Keith's Avatar
Thanks Dan...
Sounds good to me.... I'm about to order the Aero Rez... I have almost the same setup as you..hope it works for me too...
Thanks for finding/posting this Rezzzzz...
Keith.
Old Jul 18, 2007 | 12:53 AM
  #105
Matt_Burgess's Avatar
For those of you buying cheap glasspacks and cheap reonators be carefull.. I had on my exhaust a dynomax 18" 2.5" inlet/ outlet, resonator/muffler with a 3.5" body and it was galvinized, not stainless. Anyways i wanted to change it out for a Magnaflow 22" long with a 4" body to quiet things down a little bit more. When i looked in the inside of the Dynomax galvinized resonator, it was all collapsing in and all rusty looking. It wasn't strait through no more...
With just the swap of those two resonators/mufflers there was a gain in performance my but dyno would say about 5 more horse power due to the collapsing of the old one.
So what i'm trying to say is i never new the non stainless resonator was collapsed and robbing hp, as it takes a long time to slowly fall apart. I only had it on there for about 6 months. So just make sure you use a stainless one..
Old Jul 18, 2007 | 02:56 AM
  #106
Mid_Life_tC-risis's Avatar
^^What was collapsing, the inside perforated tube or the fiberglass around it? Was there damage to the outside of the resonator?
Old Jul 18, 2007 | 03:20 AM
  #107
Yea it was the perforated tube that had rust on it and was all warped looking and in the middle of the resonator there was a section, about 2" that was collapsing. Blocking like a third of the flow through it... The outside was fine, just a little serfice rust..
Old Jul 18, 2007 | 10:46 AM
  #108
So it was one of these?
http://www.dynomax.com/products/bp.asp
Old Jul 18, 2007 | 11:22 AM
  #109
Originally Posted by Mid_Life_tC-risis
Thats it, Yup..
Old Jul 18, 2007 | 03:57 PM
  #110
OK, thanks. I'll cross them off my list.
I guess for a small resonator, 12-18" (besides the Aero's) these stainless from Vibrant look like a good choice, sold by Dezod:
http://www.dezod.com/cat_resonators.cfm
Old Jul 18, 2007 | 05:02 PM
  #111
tCizzler's Avatar
Originally Posted by Keith
Thanks Dan...
Keith.
No problem, glad i could help. My friend takin the video said it sounded badass on the outside and he could barely hear any rasp at all even as i passed him. The video is deceiving but as i was passing him he was only about 5 feet away.
Old Jul 18, 2007 | 09:47 PM
  #112
tCizzler, what's your set-up exactly, are you running a high flow cat or just the Aero Resonator?
Old Jul 18, 2007 | 11:56 PM
  #113
tCizzler's Avatar
I am running exactly this.....
DC header..... Invidia S-pipe........stock midpipe flange with stock cat..... About 2" after the cat, the midpipe was cut off and replaced with 2.5" pipe for the rest of the pipe........ next comes the Aero resonator.......then back to the OEM style magnaflow 2.5" in/out muffler. It sits exactly the way the OEM muffler does (under the trunk space and side to side).
But if i was to give some advice for someone starting from scratch... i would say NOT to jump up to 2.5" piping. It doesn't add any noticeable power and makes the rasp and noise a little bit louder.
Old Jul 19, 2007 | 02:41 AM
  #114
NycMiner's Avatar
sooo what are you guys installing these resonators on? custom midpipes? stock ones? or something like the zpi one?
what sort of midpipe/resonator set up would i expect to want for a MMW header with HKS axleback?
Old Aug 6, 2007 | 04:01 PM
  #115
what if you were to do this: Megan header>Megan s-pipe>Megan midpipe (but eliminate the cat and replace it with the Aero Resonator)>stock resonator> remaining pipeing>axle back exhaust... can this work??
Old Aug 6, 2007 | 04:07 PM
  #116
Sleep3r's Avatar
seems like it will but i heard there isn't a cat in the megan mid
Old Aug 6, 2007 | 04:18 PM
  #117
there are 2 resonators in the megan midpipe? a small one and a bigger one?
Old Aug 6, 2007 | 04:21 PM
  #118
Sleep3r's Avatar
no i use to have the megan mid and i believe the resonator its got in there is smaller than the OEM, and there is no CAT in there, so honestly if your going to add an aero res. in there you might as well just go with a custom mid. i know you prolly want it just because you want a full megan exhaust system, but going custom should be cheaper as well
Old Aug 6, 2007 | 04:25 PM
  #119
well i just purchased a megan midpipe w/ an aero resonator already welded on for 170 bucks... was that worth it???
Old Aug 6, 2007 | 04:30 PM
  #120
Sleep3r's Avatar
oh ok thats a good deal, because a brand new megan mid goes for 180-220
