transmission actin up?
Old Jan 18, 2008 | 05:55 PM
StreetStarsTc's Avatar
Default transmission actin up?
Okay guys. So I'm driving like 60mph on the highway and it felt like i braked and hit the gas again; as if i was messing around with the throttle. Now I wouldn't know if this could be a throttle body problem. Or if it could be a transmission problem. Any ideas?
Old Jan 19, 2008 | 07:42 PM
bigwillystyle23's Avatar
clean your mass air flow sensor or something. has it only done this once? i dont think a manual transmission would do somethin like that. auto, maybe.
Old Jan 19, 2008 | 10:46 PM
happened 3 times. idk. it might be spark plugs. it might be maf. or tranny. or even boost leak? but i wasn't even in boost. so i'll have to see.
Old Mar 27, 2008 | 02:52 AM
changed the spark plugs. how do i clean the mass air flow sensor? just blow air into it when the car is off?
Old Mar 27, 2008 | 05:14 AM
Guru's Avatar
Definitely not a transmission problem. Sounds like something is dropping out. Not the TB though as that will trigger safe mode since it is DBW. does sound like MAF or wiring short. Any CEL's?
Old Mar 27, 2008 | 12:45 PM
yup a CEL. I checkeed it a few days ago. Said Cylinder 1 and 3 misfire. But that was before the spark plugs. After I put in new plugs, i haven't checked it yet. I need to check it now and see what happens. Oh n my o2 sensors are somewhat off...could those affect if as well?
Old Mar 27, 2008 | 12:59 PM
they make special mass air flow sensor cleaner. just unscrew it from your intake and give it a good spray down.
and i doubt your o2 sensors would have anything to do with it.
Old Mar 27, 2008 | 07:15 PM
okay thanks. i'll go check a local shop after this weekend, i need to fix it. it definitely annoys me
BlingSlade
Oct 19, 2016 12:39 AM
a23r
Feb 1, 2016 04:05 AM
carbinefreak
Oct 21, 2015 02:21 PM
Pkdust
Oct 20, 2015 04:27 PM
user9430961
Sep 24, 2015 01:09 PM
