Won't Start, No Crank. New Bat. New Starter..
Old Sep 19, 2020 | 02:25 AM
kao907's Avatar
Default Won't Start, No Crank. New Bat. New Starter..
Need help. Just bought 2008 Scion tC from the auction and replace battery and starter.
Car won't crank. Need help immediately.
Thanks.
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; Sep 19, 2020 at 06:18 AM. Reason: Moved to Correct Forum by Administrator
Old Sep 19, 2020 | 06:34 PM
62Fender's Avatar
Are you sure it's not locked up? If not, I would inspect the battery and starter cable assemblies stem to stern. Look for fraying wire and or damaged cable connectors. If everything looks good, consider an alternator test. If the test fails, have the alternator repaired or replaced.
Old Sep 21, 2020 | 12:38 AM
kao907's Avatar
Took alternator to autozone and had them test it. And it good. I check all wires are good. Do I ha e to put the car in neutral before trying to turn the crank shift bolt? To check to see if the engine is seized or not.
Old Oct 13, 2020 | 09:44 PM
Bretts's Avatar
is it automatic? if so, it may need a neutral safety switch. try shifting to neutral and starting the car.
Old Oct 14, 2020 | 07:54 PM
62Fender's Avatar
Good call. Forgot to ask about AT.
sulkinethan
Jun 8, 2020 03:03 AM
rickyb
Jul 19, 2019 06:15 PM
drocha1026
12
Feb 18, 2018 11:13 AM
memback
Nov 29, 2010 08:25 PM
idriveatC
Jan 17, 2009 09:25 AM
