zex nitrous wet kit
tap the fuel rail at the end of it...if your looking at the motor it should be the passenger side of the fuel rail. it will be flat so just drill and tap there. sorry cant help on throttle body wire
Check this thread to get the wiring, what year is it?
https://www.scionlife.com/forums/viewtopic.php?t=138455
What input does the kit need.
For the 2007 tC:
"The throttle body assembly detects the throttle valve opening angle as a control signal, which is input into TERMINALS VTA1 and VTA2 of the engine control module."
VTA is pin 6 and VTA2 is pin 4 of connector T1. The RPM sensor goes from the ECU to the dash gauge, listed as TACH on pin 1 of connector B from the ECU.
Check the appropriate diagrams for the year of your tC. One of the other files shows the wire routing and location for every connector, and a third one shows the pin pattern. Hope that helps.
For the 2007 tC:
Originally Posted by 1loud2k6sw
hey blue tc man.... you know who i am. help me figure out what all we gotta do to get this nitrous workin.
http://www.coldfusionnitrous.com/dvd/video.htm
click on the second video and they go over tapping into the fuel. NOS sells a barbed T fitting that your 20in fuel line can screw into instead of the schrader valve,
what else are you guys having problems with?
thanks man. i been tryin to find a video like that. i aint been in2 much. same old stuff. wantin my nitrous on lol.
I wish my nitrous would get here I got bored and put my purge button in today lol
spawnconnery
Dec 18, 2014 08:38 PM
Basebllstar
Dec 17, 2014 07:30 PM
