2az internals
Old Jul 22, 2006 | 06:24 AM
  #81
soros151's Avatar
and about the durability issue?
Old Jul 22, 2006 | 06:31 AM
  #82
zer0's Avatar
depends, are you racing this motor all the time? High reving it every day? If it is a race motor titanium valve retainers usually get replaced when you rebuild... But for your use, they will be nice and light.
Old Jul 22, 2006 | 06:34 AM
  #83
soros151's Avatar
Do you think this set of HC pistons brings the rings?
https://www.raceeng.com/p-7939-toyot...885mm-111.aspx
Old Jul 22, 2006 | 06:35 AM
  #84
soros151's Avatar
is all the kit?
Old Jul 22, 2006 | 06:40 AM
  #85
zer0's Avatar
not sure, call them...
If not they should only be around $65 for a set of rings.
Old Jul 22, 2006 | 06:47 AM
  #86
soros151's Avatar
Okay, here is a complete racing build up (IF the pistons bring the rings), and this is for N/A setups...
And the cost is....TAN TAN TAAAAAN!!!
without S&H: $1,306.97
Old Jul 22, 2006 | 06:49 AM
  #87
soros151's Avatar
Here is my list of those mods:
MAIN BEARINGS:TOYOTA/SCION 2AZ-FE (SET)
ROD BEARING:TOYOTA SCION 2AZ-FE (SET)
SCION TC COMP PLUS VALVE:29mm/EX (EA)
SCION TC COMP PLUS VALVE:34mm/INT (EA)
SPRING LOCATER: SCION TC 2.4L (EA)
VALVE SPRING:SCION TC 2.4 (SINGLE) (EA)
TOYOTA 2AZFE:88.5mm-11:1 (SET)
Old Jul 22, 2006 | 03:25 PM
  #88
zer0's Avatar
Care to compare prices???
http://www.zeropointindustries.net/s...cPath=23_28_80
Old Jul 22, 2006 | 08:16 PM
  #89
soros151's Avatar
I did already, and a Port and Polish done locally and all those parts are way under the price of getting the things from ZPI.
Old Jul 23, 2006 | 02:42 AM
  #90
Schuller's Avatar
your reasurch is aawsome. what parts are availablr for the bottom end?
Old Jul 23, 2006 | 05:31 AM
  #91
soros151's Avatar
Okay, what parts are available for the bottom end? What I researched was about the same parts that are available for the head and also our piston options for us. Looking at the Stage 2 Head from ZPI and its components but also taking into this the Main bearings and the Rod bearings, the price would be over the ZPI Stage 2 head, but with those last 2, the price (in ZPIs website) would go over mine by a lot, get my meaning?
Old Jul 23, 2006 | 05:51 AM
  #92
jam0321's Avatar
rods and pistons are out and of course bearings. ARP bolts are also availab.e. Everything is out there now to make a bullet proof bottom end
Old Jul 23, 2006 | 07:15 AM
  #93
soros151's Avatar
For a N/A setup below 300whp I think the stock rods will be okay, I'm not building the super All Motor 2AZ engine. I'm keeping it below that so it can be more reliable.
Old Jul 23, 2006 | 04:05 PM
  #94
jam0321's Avatar
for NA motor, I would go with some higher compression pistons. That's about it. JE Pistons has 11.0:1 available.
Old Jul 23, 2006 | 10:12 PM
  #95
soros151's Avatar
I already thougth so.
PseudoKirby
Mar 28, 2016 08:45 PM
6885BLM8435
Aug 19, 2015 03:08 PM
wejarrell
10
Aug 5, 2015 09:19 PM
marsman328
Regional - Pacific Mid
Jul 28, 2015 09:43 PM
PseudoKirby
Jul 24, 2015 03:25 PM
