AEM F/IC Setup
Ok found an exhaust leak between hot side and manifold actually 2 out of 4 dezod nuts were missing, dont how brobably because they were too short !
I went and bought longer bolts and screwed them in.. How dangerous is it to drive with exhaust leak ?
even thou i put missin gones in, there is still alot of leaking and i need to drive to base 200 miles.. will i make it if i stay out of boost ?
u'll be fine, just try to stay out of boost. It all depends on how bad is the leak. I had the same issue after I installed the ss gasket, I was missing one of the bolts and the car started running lean. I just had to go to lowes and get 1 in long ss bolts and ss lock washers, added some thread locker juice ;) and gave it some muscle. Is ur gasket in good condition? If not, get one from dezod and try what I did. It's been working great for me 'till this day.
Forgot to mention, if ur afr's are too high at cruise (16 and above), try adjusting ur o2 map. It helps if u got a laptop to hook it up to, that way u'll be able to adjust the FIC the first couple of miles of ur trip and u'll be fine for the rest. It's really easy to do. Post here or PM me if u got any questions.
I need a good base map . Please !!!! Also how do i start to tune just got it running today ? I installed some one elses map and I got allot of smoke out the exhaust !!! Need Help Please brian.d.garrett@us.army.mil
send it to brian.d.garrett@us.army.mil
Im running a precision turbo its ball bearing Im not sure on the specs i think its a sc 34 or something like that one said or the houseing says a/r 60 and the other says a/r 63
as for the wideband I need one and what do they hook up 2 ?
I don't have plates on my scion right now waiting for them to come in the mail
The car seems to be idleing pretty good . But when i took it for a test drive there seemed to be way to much smoke When ever I boosted ther was a big cloud behind me .
Im going to work right now but when I get home Ill be working on gettin this thing running better Thanks for all your help guys Brian
ok i'll send the map today, but im not sure how well it will work , since we have different turbos...
when i'll have lunch i'll send it .. or after work , but it will be today.
So i talked to my tunner today . He said I shouldn't even drive my car until he tunes it . He wants 600 buxs . I might be getting a wideband for a guy I know . Hey crush if I get it you'll have to help me tune this thing . I running "your" map right now . I found the line going to my wastegate was leaking . So i'm going to fix that today . anything else you can tell me about The AEM fic . like other stuff it can do . I saw something on there that said logger ? what that ?
Ok, btw i just spoke to a tuner from Austin his name is John and i guess he somehow works with SoulSpeed performance. he adviced me that he usually charges 500 for a tuner.. but because i spoke with SoulSpeed and i told him i'm military he'll charge me 350 out the door. and he uses dyno jet dyno.
he said he tuned FIC before quet a few times but never on a scion tc.
what do you think crush about that...
And the shops name is Protech performance found them by their phone number.
you heard anythign about them ?
