Custom Fuel Rail
Old Nov 9, 2006 | 04:07 PM
318_tC's Avatar
Default Custom Fuel Rail
I need one made, does anyone know of any or someone that can make them.
Old Nov 9, 2006 | 04:09 PM
318_tC's Avatar
Also Need Fuel Pressure Regulator
Old Nov 9, 2006 | 04:18 PM
RSracer's Avatar
I know that atpturbo.com has blank fuel rails that only require the hole for the injectors. I think they were charging $10 / ft. That might be a good start.
Old Nov 9, 2006 | 04:24 PM
318_tC's Avatar
ummm.... i donno bout all that...
Old Nov 9, 2006 | 04:29 PM
BOXMAN's Avatar
318 tC contact BDL they are looking for a stock TC fuel rail to start the Tc project. I spoke with them at Sema they didnt know Scion owners were converting to a return system already.
Old Nov 9, 2006 | 04:30 PM
318_tC's Avatar
BDL? Got a link?
Old Nov 9, 2006 | 04:34 PM
BOXMAN's Avatar
I dont just google BDL and Honda at the same time. Very very nice product and they have you covered on the regulator as well.
318_tC's Avatar
I heard you dont actually need a custom fuel rail to goto a return setup I heard you can
Put a T in the feed line
Run one end into the rail
The other end in the FPR
Then return back to the tank
Any thoughts on that?
Old Nov 9, 2006 | 04:36 PM
fusionscion's Avatar
contact kellen at craven speed... they are immerging into the scion market... i personally have a custom fuel rail setup for my turbo'd box, and it really helps out and pairs up nicely with my 370cc injectors... just email or call up kellen and tell him peter sent you... he will hook you up and get you exactly what you need...
Old Nov 9, 2006 | 04:39 PM
318_tC's Avatar
thanks
Old Nov 9, 2006 | 06:34 PM
318_tC's Avatar
GOT MY FUEL RAIL TAKEN CARE OF WOOHOO
Old Nov 9, 2006 | 07:21 PM
did you end up contacting kellen?
hope everything works out for you..
hope everything works out for you.. post pix when you install man
Old Nov 9, 2006 | 09:10 PM
Simplyscion's Avatar
Team No Limitz
if you need any help on the return line setup I did it to my xB a long time ago when I did the turbo setup. It was easy as hell...did you already change your fuel pump? As far as FPR I would go with the Aeromotive, great unit. Dont forget to get yourself a fuel pressure gauge as well if you havent...you dont need an electrical one unless you wanna monitor the FP in the cockpit. I did in the xB, but the Aeromotive has spots ports where you can attach a mechanical gauge to it.
Old Nov 9, 2006 | 09:14 PM
318_tC's Avatar
Aeromotive FPR
Fuel Pressure Gauge
Walbro 255 Fuel Pump
500whp its coming...
Old Nov 9, 2006 | 09:16 PM
Team No Limitz
Originally Posted by 318_tC
Aeromotive FPR
Fuel Pressure Gauge
same setup I had...only thing is I was lucky enough for Perrin to make a fuel rail for the 1nz motor so I didnt hafta go custom for that...be prepared to spend a lot of money on Earls AN fittings as well
BlackKnight
Sep 15, 2015 06:42 AM
Jonny5ive
Jun 12, 2015 08:06 PM
P944
Apr 30, 2015 06:04 PM
xa007xa
Mar 31, 2015 09:24 PM
yhwhdesign
Mar 7, 2015 02:01 AM
