cylinder #4 no compression
paul can you get vband housings for precision turbos to mate up to your turbo manifold? not sure i will have the money to buy a block from you but next year i wanna switch up my manifold go to standalone and possibly a new turbo if noone makes a vband housing for my pte 5857
Will it bolt up directly to our setup? Yes.
Will it have the same geometry as the slick TiAL housing? No.
Will it require mods or fab work on your end to make 100% fitment? Maybe.
Turbine housing options:
- T3 .63 or .82 A/R with 4 bolt (2.5") discharge
- T3 .63 A/R with 5 bolt discharge (with or without wastegate hole)
- T3 .63 or .82 A/R with 3" V-Band discharge
- V-Band inlet .64 or .82 A/R with V-Band discharge
- T4 Tangential .58 or .68 A/R with 3 5/8" V-Band discharge
- T4 Divided .84 A/R with 3 5/8" V-Band discharge
- Mitsubishi .63 A/R
- Buick .63 A/R
- GMC Syclone/Typhoon .85 A/R
Note the Vband inlet with vband discharge - that should be what youre looking for. The housing is around $175-225 direct from Precision IIRC. (I had to replace my housing a lil while back.)
- Buick .63 A/R
Yeah exactly, did you want me to take those injectors up to DW for you for cleaning/inspection? Its just really strange all the other cylinders looked perfectly normal with avg carbon buildup, makes me think maybe the injector got stopped up or something causing that cylinder to run extremely lean.
yea man il either mail them to you or see if i can somehow get a ride up to your house or somethin. maybe il hitch a ride with harry up there. probably easier for me to mail them cuz im supposed to be goin to little sahara this weekend. honestly i will be happy to kno that an injector caused it to fail lol cuz i dont wanna put it back together and the same thing happen all over again. and is it possible to run over sized rings if need be?
i have dezods big reds the same ones matt has. it is very well possible that it could of gotten dirty some how. nick wat do they charge to check/clean injectors?
Yeah, I think Matt has those as well. I thought they were like re-branded DW or something, but I couldn't find them on their site.
Im running their 1300's backed by 2 DW301 pumps. Im not sure what brand inj they are that hes running - but they are "big red" 850's I believe.
