Flywheel
Old Sep 1, 2006 | 01:07 PM
tCduck's Avatar
Default Flywheel
Anyone have a slightly lighter flywheel than the stock. Because I know I wont be racing my car daily, Im like most its my everyday car, and I dont want to have that ligther flywheel and spend that money when I shouldnt have to. If you have a good flywheel, where did you get it from and who here just uses the stock flywheel?
Old Sep 1, 2006 | 02:33 PM
Simplyscion's Avatar
Team No Limitz
Im runnin a fidanza...i think its around 9lbs which aint bad...stock is around 16lbs I think...its pretty cheap to, you can find it for about $240
Old Sep 1, 2006 | 02:38 PM
Smthkd's Avatar
Most people are buying the Fidanza Flywheel. Its also good to upgrade your clutch at the same time.
Old Sep 1, 2006 | 03:01 PM
JSC_Speed's Avatar
Default Clutch Masters
Clutch Masters has an aluminum flwheel that weighs about 10 lbs.
Both the Fidanza and the Cluthch Mansters seem to be reliable and decent for daily driving.
Old Sep 1, 2006 | 03:22 PM
DriveEuro's Avatar
The lightened flywheel helps to lessen the throttle delay too. Only downside to the flywheel is the install price. Most people don't have the facilities to take out their tranny. That's the only thing that is keeping me from buying the flywheel. I just don't have the facilities to take out my tranny.
Old Sep 1, 2006 | 07:01 PM
Rasta's Avatar
Lightened flywheels help with wheel spin but takes away from top end speed.
Old Jun 12, 2007 | 08:04 AM
ALaS's Avatar
stock :20 lb
fidanza : 12 lb
ALaS's Avatar
You're wrong it doesn't take away from top end speed.
Old Jun 12, 2007 | 03:11 PM
rhythmnsmoke's Avatar
Music City Scions
Facilities? All you need is a house with a garage man.
Running the ZPI lightweight flywheel here. Weighed it before installing, and it came in right at 9 lbs. Daily driveability was not effected. The flywheel is noticeable when you race it.
Old Jun 13, 2007 | 07:20 PM
chuynh207's Avatar
I have the ZPI flywheel as well. My recommendation is that you get the flywheel, street/strip clutch (both from ZPI) and Quaife LSD. Get all of that and have it all installed at the same time. That way, you'll never have to go back and have it redone (unless u burn out ur clutch)... Also, the flywheel doesn't GIVE you more HP, it just lets you get to your powerband faster. Same with a lite crank pulley.
Old Jun 13, 2007 | 07:54 PM
Team No Limitz
Originally Posted by ALaS
stock :20 lb
fidanza : 12 lb
stock: 16lbs
fidanza:9 lbs
not 20 and 12
Old Jun 13, 2007 | 07:56 PM
Mr_Meaty's Avatar
So does an aftermarket clutch like a clutchmasters, act or spec not come with a flywheel at all? Thy use the stock flywheel?
Or would you buy a clutch and a flywheel but end up not using the flywheel that comes with the clutch?
Old Jun 13, 2007 | 08:01 PM
Music City Scions
^^Clutches don't COME with flywheels. Two separate parts, that require two purchases. But you can continue to use your stock Flywheel and an aftermarket clutch if you want.
Old Jun 13, 2007 | 08:04 PM
equinox2355's Avatar
Default Re: Clutch Masters
I got the clutchmasters one, and it says it has a replaceable friction plate or whatever its called... I cant seem to find where I would get that, so that when I need it I have it.
Any idea as to where I can get it?
WRX1316_TcVicent
Jul 22, 2021 06:06 PM
Mjdavis1994
Sep 21, 2015 04:42 AM
5N1PE5
Aug 3, 2015 11:25 AM
BrokenTC2
Jan 27, 2015 03:32 AM
