i hate blown turbos...lol
yea so its not quite blown yet but its smoking when i shift at wot
its def on its way out this makes blown turbo number 2....so im rebuilding both turbos and putting one on and the other for sale or spare
it can even if its just blown seals. oil on the hot side will burn and turn into little lumps of hard carbon that will grind away at the bearings and clog up the oil passages.
lol yea not my rings 37k im sureime fine plus i saw oil in my charge pipe so yea... lol and i dont smoke on wot i smoke only when upshifting
still boost fine for now...i just got ____ed at my gf and did a nic elong 2nd gear burnout infront of her house bouncing off revlimit my stock clutch was not loving that lol i had smoke everywhere clutch and tires
im gonna keep this here and edit later
Well if both turbos do not have any shaft play and there is oil in the charge pipes then I would make sure you are not having an over oiling issue. Just something to look into since you are going through multiple turbos.
funny cuz i had garrett internals...
yea it was sent to blaast performance to get built with garrett parts... this wasnt the reason it went on me...i just noticed that my oil return lineright before the oil pan dip down lower than the fitting which means oil is puddling and not going straight down to the pan
, must have happened when i re sealed the oil pan 2 or 3 weeks ago
no it was because my oil return... and the first turbo blew like 2 years ago after just 5 hours of driving that turbo was renderred useless...the shaft broke
the one sitting in my garage was from the previous owener of my kit he sent 2 turbos 1 blown and one used
OpTicaL
Sep 16, 2015 10:25 AM
