Idling problem
Idling problem
When I make sudden stops or sometimes normal stops my idle bounces back and forth from 800 to 500rpm's. When it dips to 500, the car starts to vibrate quite a bit. I'm running the turbonetics kit with an emanage blue at 8psi and thats about it.
Can you guys please help me troubleshoot and give suggestions? Your input will be greatly appreciated. thanks
Mine does the same thing sometimes.....as does many others here on SL. It seems to be quite normal and won't harm a thing. Also, it doesn't seem to be a manual vs. auto problem either, although it's a bit more pronounced in the auto cars.
Unless your car is stalling-out I wouldn't worry about it too much.
It could be your vacuum. When you apply brake pressure, it alters your vacuum a little. It'll alter it more if you have a vacuum leak somewhere.
I have a T'netics kit and it does oscillate back and forth sometimes, but not so much to where I think it'll die. I'm on the stock Unichip right now.
I would check for vac leaks, then clean the TB, and if you dont have a recirculated BOV, I would make it recirculated. My buddy was having the idle issue with his turbo until he recirculated it, and he doesnt have the prob anymore. And he also does hard stops.
A bit quieter too!
I have the same problem, when i throw it into nuetral i see the RPM's get below 1k...also the AFR's bounce to 16.3 (the red) So im not sure if i should be calling my tuner now maybe this is normal with you guys..
greddy 18g turbo with various custom parts and AEM FIC
the other thing that could be slightly "magifying" this normal issue with your guy's tCs is running forced induction. This flux in the rpms... mainly when coming to an idle after higher rpms is due to the VVT-i, which is prefectly normal that's how this type of valve train works. From what I've seen N/A setups aren't as noticable with that jump as forced induction setups do.
RY_TC07
07-18-2017 05:18 PM
cid_mcdp
01-05-2015 02:45 PM
