Minor oil leak. bad seal?
Well Ive smelt oil the last few weeks when i came to a stop, but everytime i checked my oil i lost none!
Just figured it had to be something small. Today i finally found were its comming from!
A very little amount(A drop every few minutes) is comming from, Right were the S/c shaft meets the s/c. and lands on my header!
I took a pic of were its comming from, Is there a seal there? or could it be the start of a bad bearing! You cant see any oil in the pic. it done leak enough to leave a stain.
most people are burning massive amounts of oil, most lilkly through the motor. This is not the typical leak for s/c's..
And yes it needs to be fixed, why i asked if it was a seal or bearing so i can fix it
My friend just got that problem fixed....
I dont know exactly where its at, but there is a part # on here somewhere for a better seal than the TRD part, see if you can get that one installed...
There are lots of threads on various forums (you can search them on here) regarding this issue. So yes, it is a common issue for the SC as far as its issues go. There are threads about replacing the seal on the shaft, part numbers, etc.
RY_TC07
Jul 18, 2017 05:18 PM
awdmofo
Feb 8, 2016 05:58 AM
xb4lf
Apr 4, 2015 07:15 PM
mischadoll
Mar 9, 2015 05:48 AM
