Motor Build Start up Problem
Originally Posted by m6ar2cel6oTC
same as what? 20 something percent? or 0-2%?
Assuming your engine sensors are not at fault (i.e. maf sensor), you may want to try a fresh set of stock heat range spark plugs. The tC will be very, very diffcult, if not near impossible to start or keep running if the plugs are soaked with fuel. Trying to start a newly built engine makes things even worse.
Another thing you can try too, since you have the EMU.....start the car with the gas pedal to the floor, it will fire the plugs without introducing fuel into the engine (designed as a way to clean the plugs if they get fouled out). After a few cranks, let off the gas pedal and start the car normally and see how it goes. Just make sure your EMU's tps sensor is calibrated to recognize 100% tps, otherwise the feature will not work.
Good luck and let us know how things turn out.
- Toan
let me know when you can besdies sunday and i'm down to take a drive up there and check it out. they wouldnt mind also.there going to put in another maf sensor today to see if its that. they are going to use soflo's maf to check it out. they said they checked my maf with a voltage meter and it was working so we will see. i will call them in a little bit and let them know everyones comments and see if they try it out also.
- Toan
