N2MB WOT BOX issue
Anybody have an issue with the no lift shift feature engauging when shifting at at red line but letting off the gas in between shifts? If I always flat shift the wot box works as it should, it's when I power shift and don't want it to come on it does. Hope this makes sense. I have played around with the voltage settings and nothing seems to help. It kind of sucks because if I don't want this to happen I always have to flat shift on red line pulls. What is the best set up to program in to cure this? Side note....when this happens I have already shifted into the next gear normally, then the motor cuts out with the clutch out and gas pedal to the floor.
Ya exactly. Doesn't happed every time, but enough to make me mad. Can't be good for the motor at full boost around 6k rpm. If someone is using this and has zero issues could you please tell me you lock out points. Or even better a snap shot of your screen.
Here's a shot, for some odd reason my 2-step stoped working about 5 months ago. Got to figure that one out.
I have the TPS a lil low that way I could downshift from 5th to 4th without much drama, but u could definately raise it
CombatmedicR56
Nov 12, 2020 01:53 AM
chowdahound
May 20, 2015 06:46 AM
