need help bad and quick
Old Nov 17, 2009 | 08:52 PM
Blue_TC_Man's Avatar
Default need help bad and quick
ok, got a tune and took the car out for a test drive to make sure it would make it to the tuners. It was doing fine, and I was taking it slow. All of the sudden AFR's went nuts and it cut off. Then to get it home I had to give it throttle a lot or it would cut off. Got it home and there is oil all over the transmission side covering the transmission but idk what or where its comming from any ideas?
3.8psi wastegate spring stock injectors
Old Nov 17, 2009 | 08:56 PM
highvoltage1's Avatar
Um well defintely sounds like you have an oil leak. Check that first. Check for a boost leak and exhasut leak. Was you BOV working right? Do you have quality parts or ebay crap?
Old Nov 17, 2009 | 09:01 PM
garrett turbo, tial wastegate, ebay intercooler.
oil fittings on the turbo are dry, BOV was working I could hear it .
oil pan is dry , but reads no oil on the dipstick
Old Nov 17, 2009 | 09:20 PM
Ace83's Avatar
Ronin Scion
^^ you have an oil leak.. it might be your tap to your turbo oil feed line.. its the one closer to the tranny.. dont drive it until you refill your oil
Old Nov 17, 2009 | 09:24 PM
yeah I found it. The dezod feed kit I got didnt come with everything so the T i was missing I replaced with some hose and Don is helping me set it straight now. The hose blew out god that was scary
Old Nov 17, 2009 | 09:25 PM
weezyfbayba's Avatar
its comeing from the tap from ur feed line to the head.. same thing happened to me. besides the dieing part. just lost alot of oil.
Old Nov 17, 2009 | 09:27 PM
Yea id say loosen up the oil drain bolt and see if anything even comes out. Refill the oil and check the tap for oil drain and your oil supply tap off point as well.
Old Nov 17, 2009 | 09:33 PM
yeah I feel the dying part was due to the oil blow out im sure
Old Nov 17, 2009 | 09:37 PM
well.. gl i used teflon tape on mine to fix it ALSO! if ur useing a brass fitting into the head. it wont hold. i switched to the T that came with my feedline and it's never leaked a drop since then
Old Nov 17, 2009 | 09:41 PM
Prototype_xB's Avatar
oil pressure sending unit tap on the side of the block is what sounds like leaked. This would leak right on top of the trans. Next time use automotive RTV silicone sealent in the threads, and for added security lock tight sealent on the feed fitting on top of the turbo.
Old Nov 17, 2009 | 10:46 PM
thendawg's Avatar
Not to scare you but have you tried driving the car after fixing the leak and putting oil back in it? An oil leak won't cause the car to die - but running it out of oil and spinning a bearing causing tons of friction on the crank/rod/block will. Also blowing that hose off will cause a severe loss in oil pressure which can also lead to the same destruction of bearings. Once you get it fixed, try reving the car slowly under no load to see if you hear any rod knock - also drain the oil and see if it has any bearing material (tin/copper metal ish) in it.
Old Nov 18, 2009 | 02:46 PM
yeah I got to wait on the stuff to fix it. It did drive fine from where it happed to my hous about a 1/4 mile away I just had to give it throttle it was acting like a massive vacuum leak
Old Nov 18, 2009 | 04:40 PM
ok so good news. dipstick was dry, but I pulled my drain plug just now, and a good steady flow poured out, had atleast 2 qts in the pan still. No metal shavings in the oil, no metal on my magnetic drain plug either, so hopefully the car is ok
Old Nov 18, 2009 | 08:57 PM
good to here. Prolly the oil supply line tap point leaked then. Well hopefully you can get the proper parts and fix that soon. And further test it. Have a friend with you though so if you need to push the car its alot easier. But i really hope it dont come to that for ya.
Good Luck!!
Old Nov 19, 2009 | 02:40 AM
thanks man, all should work out
Old Nov 19, 2009 | 12:58 PM
B_Real45's Avatar
Good to hear.. keep me posted.
drgonzo92
14
Apr 24, 2019 07:27 PM
alexbarspin
Sep 3, 2015 02:04 AM
mc1114
Aug 12, 2015 02:07 AM
elwaylite
Aug 9, 2015 09:21 PM
goatbelly
Jul 12, 2015 10:13 AM
