New fuel setup.
Old Feb 16, 2009 | 07:23 PM
  #41
Crayola_G's Avatar
Originally Posted by ElevationTC
id like to see what the guys mecanica pito over in pr are running!
im pretty sure its a basic return w/ id imagine 6an lines, running a aeromotive FPR w/ a golden eagle rail....im not sure on the pump but id imagine a walbro.
Old Feb 16, 2009 | 08:25 PM
  #42
rhythmnsmoke's Avatar
Music City Scions
Originally Posted by adg016
An improper fuel cell system WILL be more dangerous than a factory system. If you choose to do this, do your homework, have a qualified race shop do the work, and don't scrimp.
We avoided the fuel cell for complexity and weight reasons.
I would be consulting PTuning about the fuel cell setup. Weight reasons? That's kinda confusing since a fuel cell weighs less. I don't scrimp on things though..
Old Feb 16, 2009 | 08:34 PM
  #43
paul_dezod's Avatar
Scionetics
KAD
Originally Posted by blown_xa
Originally Posted by SoFloTC
why use such big injectors? with a return system u wont need that big.. only reason why we need huge injectors for higher hp app's is because we dont have a regulator
he is running a 1.7 bar spring. I think that is 20-22 psi? 900cc should be great for that boost range. The purpose of the rising rate fuel pressure regulator is primarily used to keep a consistent fuel pressure and raise the pressure linear to boost. You should relate your injector size to estimated whp, not rely on bumping up the fuel pressure because that is secondary and considered a fine adjustment.
Fuel pressure does have it's advantages to an extent as well. Higher pressures allows some injectors (EV6 and newer) to atomize the fuel unbelievably. So running persay 55-65 PSI of pressure on a certain injector may yield more beneficial to the atomization properties alone compared to injector B (larger at a lower fuel pressure) in helping det.
Old Feb 16, 2009 | 08:36 PM
  #44
paul_dezod's Avatar
Scionetics
KAD
100%. TONS of potential for failure and utter chaos if not done properly on several different levels.
Old Feb 16, 2009 | 11:37 PM
  #45
yamaha16bw's Avatar
I'm pretty sure mecanica pito is running dual intake walbro pumps. Not sure about his line size of rail but the GE came out after he did his setup I believe.
Old Feb 17, 2009 | 05:55 AM
  #46
ElevationTC's Avatar
http://store.summitracing.com/partde...part=AEI-11109
how is this for my inline pump.. should work correct?
steeze69
May 24, 2021 02:57 AM
mudguy
Oct 22, 2015 04:31 PM
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
paisatronix
Sep 5, 2015 04:13 AM
