No engine management @6psi: Safe or Unsafe?
Old Jan 5, 2011 | 07:09 AM
  #41
ScionFred's Avatar
I should probably clarify my position regarding low boost without "engine management". Because the typical response is that a piggyhack is needed, I usually come down on the "no EM" side but the truth is that some form of EM is usually needed. At 5-6psi the required EM may be nothing more than larger injectors but even that small change constitutes a form of EM. A simple change in the MAS location or tube size can be considered as EM. Even a simple O2 signal modifier like the SS Enricher that I'm running is in fact a piggyhack. I suppose that even though I'm not running a FIC or GEMU, I'm still running some form of EM and a piggy. That's all.
Old Jan 6, 2011 | 01:03 PM
  #42
BlackKnight's Avatar
Music City Scions
One possibility if you were running that rich for long time you could have had cylinder wash by the fuel, causing no lubrication scorching your cylinder walls.
Brammi
Nov 13, 2016 03:46 AM
Marganne
Apr 3, 2015 06:52 PM
eric_m
79
Mar 17, 2013 12:21 AM
BlueBox
14
Jan 15, 2004 01:08 PM
