PTUNING: 3" Exhaust Dynoed with TRD S/C (Results are in
Old Jan 16, 2008 | 02:24 PM
  #61
kanundrum's Avatar
Old Jan 17, 2008 | 08:39 AM
  #62
greddy05tc's Avatar
woo hoo. i got my name on one of them. can't wait for it to show up now.
Old Jan 18, 2008 | 04:49 PM
  #63
weeloTC's Avatar
so everything was done with a stock header, that impressive, and this whole time i was just going to step it up to a 2.5 system, might as well go big know, any sound clips???
Old Jan 18, 2008 | 08:06 PM
  #64
gjpjr84's Avatar
stock header but still boosted.
Old Jan 18, 2008 | 10:40 PM
  #65
kanundrum's Avatar
Correct it was my car has a supercharger with stock exhuast including stock header the only thing it has a Bosch BPV 110
Old Jan 21, 2008 | 11:20 PM
  #66
kanundrum's Avatar
Old Jan 21, 2008 | 11:21 PM
  #67
2_much_tc's Avatar
that's awesome. were they gonna do another test with an aftermarket header with their exhaust?
Old Jan 21, 2008 | 11:35 PM
  #68
imsonofagun's Avatar
I'll try to get some dyno runs when I get the exhaust put on. I have a Megan header, Invidia s-pipe, custom 2.5" midpipe with hi-flow cat and resonator, and the Magnaflow cat-back right now.
Old Jan 22, 2008 | 03:31 PM
  #69
JPsTc's Avatar
1UP Crew
^Yea let us know how that goes
Old Jan 27, 2008 | 12:22 AM
  #70
tCtCtC's Avatar
ok, im confused. this is the normal 3" spipe back right? whats the difference between the turbo back and this? and if im getting MMW header, how would i install it exactly because this is spipe back? or would it be better to just get a dif. header?
Old Jan 27, 2008 | 01:48 AM
  #71
2_much_tc's Avatar
the turboback has the downpipe connected to it, we just have the s-pipe... and they also did this test with stock headers...
Old Jan 27, 2008 | 01:59 AM
  #72
You know how cat-back exhausts start right after the catalytic converter, but doesn't replace the catalytic converter...
This is the "Turbo-back" exhaust (includes s-pipe all the way back), just renamed "header-back" and used in a supercharged application. They do offer the s-pipe back version (starting where the stock s-pipe ends all the way back).
http://www.ptuning.com/html/Item-Des...o&ModelDesc=tC
Old Jan 27, 2008 | 02:06 AM
  #73
2_much_tc's Avatar
i might have misunderstood then...
Old Jan 27, 2008 | 02:10 AM
  #74
BrownDogg's Avatar
Can you put the 3" Ptuning catback on an N/A car? What will that do to the car performance wise and sound wise
Old Jan 27, 2008 | 03:17 AM
  #75
You can put the header-back or s-pipe back system on an N/A car, but wouldn't recommend it. You wouldn't be pushing the same rate or amount of exhaust out as an F/I application, so exhaust flow will be slower. This has a negative effect on exhaust scavenging. You would almost be better with an open exhaust rather than 3".
http://www.veryuseful.com/mustang/te...Scavenging.pdf
Old Jan 27, 2008 | 03:19 AM
  #76
tCtCtC's Avatar
ok i get it. so if im going to eventually get mmw header/spipe, then i should just get the catback?
Old Jan 27, 2008 | 03:25 AM
  #77
The s-pipe back system should work for you since it's designed to be able to mount up to the stock s-pipe. The MMW header/s-pipe is designed to work with the stock exhaust, so it should mate up to the s-pipe back exhaust. I'm not sure the Ptuning s-pipe would fit the MMW header.
Old Jan 27, 2008 | 03:27 AM
  #78
tCtCtC's Avatar
wait. now im confused.
the exhaust system is like this, right?
Header - S-pipe - Midpipe piece 1 - Midpipe piece 2 - Axleback
thats how i always thought it was? so waht would be a catback, spipe back, or header back?
Old Jan 27, 2008 | 03:39 AM
  #79
Header-back replaces everything but the header.
S-pipe back replaces everything but the header and s-pipe.
Cat-back leaves the header, s-pipe, and the catalytic converter alone and replaces everything else. It would require cutting the stock exhaust right after catalytic converter and clamping or welding the new midpipe to the stock one.
Old Jan 27, 2008 | 03:50 AM
  #80
tCtCtC's Avatar
never knew that. so with the ptuning catback, i would have to go to a shop and have them install it? sorry for all the questions, ive only dealt with a axleback.
