PTUNING: 3" Exhaust Dynoed with TRD S/C (Results are in
Ok soo. Me and my friend who has a Auto Turbo Tc compared exhaust clips. Basically his sounds a bit quieter. I am pretty sure its because the methods of F/I. I do like it coming from a TRD it is def quite louder during driving and acceleration. You can def hear it in the cabin not that its a bad exhaust note or anything but its def louder then I was expecting but come on its a header back exhaust so what do you expect.
Over all I do like it, in 5th gear just cruising you literally can't hear it at all you have to give it some gas and then you can hear it. I know this was a question for a lot of people in terms of the noise/decibel level. If you normally have some music on at volume 15/20 youll be just fine.
The main thing i do love about it is the actual power it delivers. You can def feel a 100% difference in terms of the power Even though it peaked at 14 or so whp on the dyno at high RPM's you can def tell its there with norma acceleration.
I love it! :D
I love it! :D
Ok got a Interior and exterior video. Took the other one off.
http://www.kanundrum.net/Ptuning%20Exhaust.wmv
http://www.youtube.com/watch?v=KMy4t_pdHvI
Just got the exhaust on a couple hours ago. Haven't really done a road test since the exhaust is pretty loud and it's raining with fairly heavy traffic. I'd like to get the sound a little more tame for my taste. It sounds pretty aggressive and not like a Honda with a coffee can. I just feel it's a ticket waiting to happen, lol.
I had P-tuning do before and after dyno pulls and I'm pleased with the results. Early last year I was basically stock (only engine performance mods I had were s/c, bosch 110 BPV, removed the hydrocarbon filter in the intake, and a Magnaflow cat-back exhaust). The WHP I got on P-tuning's dyno was about 160whp.
I then upgraded to the NST 9.5psi s/c pulley, NST overdriven alternator pulley, NST water pump pulley, Agency Power crank pulley, Fidanza flywheel, Clutchmasters stage 3 clutch, Turbosmart dualport BOV, Megan header, Invidia s-pipe, 2.5" high flow cat, resonator, and K&N filter. That put me up to 204.7whp on P-tuning's dyno.
After P-tuning's header-back exhaust was put on, power went up across the entire rpm range, putting me at 217whp.
I say it's a good investment for the power, but I'm thinking about tossing the Megan header for something else (get weird resonating sound at 1500rpm, and 2500rpm especially, and by the time I get up to 3500rpm, the sound is constant until redline). Like I said before, I'd also like to tone down the sound a little too. The resonating was there before the P-tuning exhaust went on though, but it's still there.
Before P-tuning exhaust
After P-tuning exhaust
AFR
PSI is about 9.2.
AFR
PSI is about 9.2.
Yeah, some reason my car reads lower than everyone else. when I went to the ZPI shootout, I had the bosch 110 and magnaflow exhaust and only got 165whp on their dyno dynamics dyno.
Promotion Tuning said that compression looked ok, and haven't had any problems with burning oil, oil going low, leaking, or supercharger breaking.
Didn't you have a Unichip?
http://www.metacafe.com/watch/114792..._back_exhaust/
There are noticeable power gains with this exhaust, but with the Megan Racing header, the sound is quite loud (ticket waiting to happen loud). The backfire that you hear is because I have a TurboSmart dualport BOV and makes the car run slightly rich when letting off the throttle (occurs more often when free revving the engine). Engine performance mods: TRD supercharger, 9.5psi pulley, lightened crank and water pump pulleys, overdriven alternator pulley, light flywheel, stage 3 clutch, K&N drop in filter, TurboSmart DualPort BOV, Megan header, and 3" header back exhaust.
