Putting my motor together tommrow.. DONE STARTED :_)
- blown clutches on cars proucing much less then the amount CC has rated the clutch for
- premature pressure plate fade (loosing its strength way to soon into the clutches life)
- blown springs from the disc
- TB chatter that is almost null and to hard to fix
- idle chatter or chatter after a brisk run that only stop when pressing down on the clutch and letting go again
- inconsistent clutch perfomance (some day grabbing well and feeling like a stg4 other days slipping in gears and feeling softer then an oem one grabbing)
- constant pedal adjustments to compensate for the clutch engagement performance
theres more but thats the jist of it... BTW some of these things happen on car not even pushing over 220 whp or TQ... and also some other makde/model ppl have reported this issue with the CCstg4 clutch...
Yikes. I hope my CC4 doesn't have these issues. I've been driving mine for a few months and its been fine, but I am still on relitively low horsepower (220ish). I do get a little chatter/squeal when I am taking off from stops, but I figured that was just part of having a higher performance clutch.
- premature pressure plate fade (loosing its strength way to soon into the clutches life)---------His clutch has 17K ALL boosted miles on it. Car is a 2008 with over 30K on it.
- blown springs from the disc-----------Driver who tries to feather a race disc will have this happen.
- TB chatter that is almost null and to hard to fix----Need more elaboration on that.......
- idle chatter or chatter after a brisk run that only stop when pressing down on the clutch and letting go again------Never experienced that, and I have had to beat the snot out of this car.
- inconsistent clutch perfomance (some day grabbing well and feeling like a stg4 other days slipping in gears and feeling softer then an oem one grabbing)------Again, never experienced this.
- constant pedal adjustments to compensate for the clutch engagement performance------Nope. Just one was made, and she is fine where is at. Makes downshifts super easy.
I think this absolutely comes down to the install and driver, whom may or may not cause many of the issues mentioned above. I am not saying CC is the end all of clutches, but for the $$, you get a hell of a product.
hell my stg4 slipped a few times.. and im NA...
I have been driving a Stage 4 equipped customer's car for the past 2 weeks DAILY. We did have to adjust the clutch pedal for better engagement, which made the clutch feel much better.
- premature pressure plate fade (loosing its strength way to soon into the clutches life)---------His clutch has 17K ALL boosted miles on it. Car is a 2008 with over 30K on it. lucky for him.. but i do know of 2 ppl right now who have had this problem. why else would CC warrenty and send ppl new clutches. its obvious something was wrong with it or defective.. again some ppl have been very lucky.. but others have not.
- blown springs from the disc-----------Driver who tries to feather a race disc will have this happen.( how else do you want ppl to get into gear? rev really high to get going and come out hard off a light?... ive had act's and excedy's and never had this problem on their high stage clutches and no one i know also has ever not feathered to get going
- TB chatter that is almost null and to hard to fix----Need more elaboration on that....... i did.. in fact i remember writing you a long ___ PM about it and some of the problems i was having.. and remember your response? because ill never forget it...
- idle chatter or chatter after a brisk run that only stop when pressing down on the clutch and letting go again------Never experienced that, and I have had to beat the snot out of this car. again.. you are lucky.. but i know of 2 other cases were this happens currently i will locate one of the members if you want them to chime in also
- inconsistent clutch perfomance (some day grabbing well and feeling like a stg4 other days slipping in gears and feeling softer then an oem one grabbing)------Again, never experienced this. Again... great for you but not for the other ppl including myself who i have talked to even on non scion cars
- constant pedal adjustments to compensate for the clutch engagement performance------Nope. Just one was made, and she is fine where is at. Makes downshifts super easy. yes mine downshifts super easy but the pedal feel has never ever been consitent in my car.. some days is rough and nice other days its as soft as stock..my OEM clutch never gave me this issue
and i can agree with you to some extent on driver or installation.. but when you have multiple with a good amount of experience installing these parts and have driven many cars with many clutches before.. you start to rule out some of these things... dont get me wrong.. i agree also for the money its a decent deal.. but at the same time.. i prefer quality or price.. and if i had known ahead of time i'd be waking up every day and worrying about how my clutch will react today then i would have just spent some more money and bought an ACT or CM clutch... not trying to be rude to you at all paul just voice my perspective on this.
TCPETE, I am not here to argue with you man. I am merely stating my perspective from an outsider whom has a customer's car with this exact setup. He is only making 220ft/lbs to the tire, so maybe he is not making enough power yet to feel the effects of the clutch. However, I'd say with over 17K boosted miles since we installed his kit that his clutch is set to go.
As far as leaving the redline, I give it 2 quick revs to about 1.5K and just blip it off with a mere toe-flip downward, and I am moving. I do not know how anyone else does it, but it seems to work VERY well with this clutch on this car.
CC had some issues with some of their earlier editions of this clutch for this app, but have made a conscious effort to refine their part and make it better. They have changed the bearing, changed the discs, changed the pressure plate to keep this product heading in the right direction. You get a lot of companies whom sell this product, but are not direct dealers who are buying older inventory that a WD has been sitting on. This process still dilutes the quality of it because they are moving older units around and people are getting the problematic units.
Again, it's a product that is contingent upon the end users install, driving habits and experience. I am NOT pointing any fingers about ANYONE on here, but you get some 16 year old whom just learned to drive, had daddy buy the car for him and now the turbo. He gets a stage 4 to hold the tq and now destroys it because he can't even drive an OEM clutch well or at all.
The clutch in essence is on the same premise of any other product like a turbo kit of sorts. Some people are experienced, know what is going on, have a great experience and call it a day, while others do not and complain about EVERYTHING from dropping the oil pan, to having to mount the intercooler as well.
Moral of the story: Some people say Sham-WOW works, while others say it's a waste of $$.
(Comic relief to this thread)
Also, what is the best way to adjust the clutch? I left mine where it was after the install. I had a clutch stopper behind my stock one so I had to relearn how to shift my car, but I imagine that adjusting it would help me out.
So far, I have a few thousand miles on my CC4 and I really like it. The only thing I don't like about it is that it is a lot more "grabby" than the stock one which is a good thing, but it makes me self-conscious when I am giving people rides that don't understand why my car is a little more rough of a ride than a normal car. haha
i drive it daily and do exactly what you say.. blip it till 1.5k rpms and slowly let it grab itself till i get going.. thats how ive always driven this clutch...
BTW i even bought this clutch from you... so would it be possible you sold me an old clutch then?... to go along with what your saying.. then i myself would be one of the ones who have been screwed getting an old clutch needing a refinement...
You can try to flip the script anyway you like sir, but understand I am trying to clarify and help. We did not MAKE the clutch.
Pete, if you bought your clutch from ANY dealer within the past 8 months (in theory assuming no issues I mentioned above) you should be fine. Anytime before that was a transition phase for them with all of the refinements.
my CCstage4 failed... my disc was perfect and my flywheel was perfect, so nobody can say i was bieng a noob driver, there was only 1 tiny glaze spot on the disc, the plastic TOB CC gives u completely took a crap and caused the pressure plate to fail and loose 5 prongs off of it lol, although i do have another CC item in my car now and i cant wait to test it out :D BTW ill be selling a CCstage 4 NEW in box and NEW flywheel soon, as soon as it gets mailed to me
Paul, just a few quick questions. I didn't realize that feathering out the CC Stage 4 is bad for it. Just curious why this is.
Ok... Let me chime in now....
First off.. Im a dealer For COMP CLUTCH. Directly through them! Great people great cust service!
OK... Now let me stat the fact on my end!
My CC stage 4 failed at 9 PSI a mear 330WHP 330FT LB!
Also, WHEN my clutch failed, i was using an OLDER pressure plate that has now been improved upon!
When i ordered this clutch and still, they rate there disk at over 350ft lb tq! It was merrly an issue with the older plate having less pedal pressure then a newly imporved one!
Also the diffrence between a 4 puck and a 6 puck is NOT 100 WHP.. And a stage 5 with my pressure plate would of failed the same if not SOONER!
I recently removed a newer stage 4 comp clutch disk and pressure plate from a customer of mine who has 19+ PSI and over 400 whp WITH 0 glazing! Showing there new stuff is MUCH improved!
Paul, coming on here and asking why i used it is kind of out of line! Your a great guy, great buisness great knolege and have helped me out ALOT! But Do not know what i was promised when i bought it through them! They were sent the dyno sheet and replaced the clutch! And as well your site says 350fl lb yet i was at 345! Your only making this issue stick out, and cause more people to hear about it..
So.. im going to end me posting more about this issue and say this...
A NEW stage 4 disk will hold MORE THEN 400WTQ FROM PERSONAL EXPERIENCE!
CC has great Cust service and will go out of there way to help anyone!
