Putting my motor together tommrow.. DONE STARTED :_)
Old Jul 29, 2009 | 06:52 PM
  #101
THansenite's Avatar
How do you guys adjust the clutch pedal?
Old Jul 29, 2009 | 07:06 PM
  #102
SoFloTC's Avatar
Originally Posted by TCpete
your cars not running period?
you need more then adjustment u need a prayer and some major work on the stop portion also. i just spoke with mike about it. do not rush the car chad... if it cant be this weekend then we can try the next.
i think it should be fine we tested it out and ive been pressing the clutch in and out everyday so far with this crappy adjustment and nothing is going wrong so far
Old Jul 30, 2009 | 07:29 AM
  #103
aen's Avatar
aen
Originally Posted by paul_dezod
Horrible mistake in Las Vegas, SEMA show time, went to Studio 54 in MGM. There was a line forever long to get in, we figured it was slamming. We stood in line for an hour, got in to discover it was mostly SHOCKING and people who also liked different things than Chris and myself. SCARY!!!!!
lol next time lemme know, lines don't exist for me
Old Jul 30, 2009 | 01:53 PM
  #104
paul_dezod's Avatar
Scionetics
KAD
Email don@dezod.com as he is a pro at this.
Old Jul 30, 2009 | 03:11 PM
  #105
TCpete's Avatar
-slide your driver seat back
-take off the kick panel on the clutch area right next to the dead pedal
-take out the spring that hooks onto the clutch pedal and the clutch pedal assembly
- Get a 12mm open wrench and look for the locking nut on the gold push rod that sits directly behind a large cyclinder right on the clutch pedal.. you cant miss it
-loosen the 12mm locking nut
-one the nut is loose, turn the rod to the drivers side to shorten the engagment point or loosen the nut all the way towards the fire wall (it will stop half way) and you can use the nut to turn the rod in the other direction (clockwise) and that will rasie the engagement point
-!! do small turns in small incriments.. start with 1/4 to half turns...
-once u have turned the rod retighten the lock nut and put the car in first and reverse to check your engagement point.. .
-depending on where you want it (most ppl suggest middle of the clutch throw) you can go back down and turn it either to the counter clock wise to lower the point of engagement or clock wise to raise the point of engagement.
it will take you a few times of playing around with it but eventually you will find a spot thats comfortable for you and easy for you to drive....
once your satisfied with the engagement point.. secure the locking nut and make sure its tight (dont over tighten)... then put back the spring on the pedal and on the assembly, and reinstall the kick panel.. vuala.. you done.
Old Jul 31, 2009 | 03:46 AM
  #106
m6ar2cel6oTC's Avatar
so whens d-day (dyno day) waiting on your numbers and psi!!!
Old Jul 31, 2009 | 03:50 AM
  #107
SoFloTC's Avatar
hes not even sure when hes getting tuned.. hes broke lol, i just wanna see this 27 psi on race gas that CFT keeps asking him to do... that wud be bosssss
Old Jul 31, 2009 | 05:16 AM
  #108
no what he should do is get tuned on regular premium gas to know what he gets as a DD. so atleast he knows how much power he has if he races on the street against a car that thinks is fast!
Old Jul 31, 2009 | 05:30 AM
  #109
SoFloTC's Avatar
ya but im just curious to see wat 27-30 lbs and race gas will put down
Old Jul 31, 2009 | 11:05 AM
  #110
ElevationTC's Avatar
Well just got a raise at work.. WOOT.. and also am recovering from paying from my motor!
So waiting on my water meth kit.. and then me and omar are tuning it..
i only want 400 ish on street tires. as its hard enough to drive at 362 with falken azenis! ill be getting drag radials and 17" front rims to go out "playing" on and i will be on 110 pump gas with water meth for this..
and for my slicks ill be at 27-30+ psi on c16
Old Jul 31, 2009 | 12:20 PM
  #111
t_urbo_C_harged's Avatar
Old Jul 31, 2009 | 02:47 PM
  #112
cool cool. what drag radials? next time i go to the track i am going to use luiggi's bfgoodrich drag radials from his sti but i just nervous. never dragged wth tires like that. i dont want to break an axle. i need to learn how to launch with those!
XirtaXa
24
Jan 14, 2025 03:49 PM
Jordly221
Feb 13, 2019 05:29 PM
cid_mcdp
Jan 5, 2015 02:45 PM
BV19869
Dec 11, 2014 06:05 PM
lexobx
Scion xD Drivetrain & Power
Dec 7, 2014 05:52 PM
