Quick Question about AFR Sensor
Old Jan 25, 2011 | 08:29 PM
draxxus0321's Avatar
Music City Scions
Default Quick Question about AFR Sensor
so i have a glowshift afr wideband. my question is do i need to use my o2 sensor on my mid-pipe or can i just remove it and use that hole for my wideband sensor? will it mess anything up with running boost not running the second o2 sensor? thanks in advance i know its probably a dumb question.
Old Jan 25, 2011 | 09:07 PM
a-mendoza's Avatar
youll just get a check engine light but it wont do anything bad to your car nor go into limp mode not having it. Go for it. Im doing the same thing right now with no problems.
Old Jan 25, 2011 | 09:10 PM
crush02342002's Avatar
x2
but if you dont want a cel for lack of secondary o2 sensor you can weld in an extra bung.
Old Jan 25, 2011 | 10:41 PM
emrules2001's Avatar
Get a second o2 bung welded in from an exhaust shop, I wouldnt assume it would cost more that $50, if that
Old Jan 26, 2011 | 04:55 AM
Music City Scions
well i think im just going to go with not running it for mow. thanks guys i appreciate it
Old Jan 26, 2011 | 03:17 PM
johnhawkins's Avatar
I would say $20-25 would be the most I would poy to get one welded on. personnaly i would get a seprate one welded on the down pipe a little closer to the action. good luck man
Old Jan 26, 2011 | 03:53 PM
Music City Scions
another question, will any LSU 4.9 Wideband o2 sensor work with the glowshift digital afr gauge?
Old Jan 26, 2011 | 09:55 PM
Syldrin's Avatar
if you take it to a local exhaust shop with the pipe off the car it wont cost very much at all.
S7ephavs
Mar 22, 2015 12:09 PM
GoodVibes
Scion xB 2nd-Gen Wheel & Tire
Mar 3, 2015 09:47 PM
ShadowMage
16
Jul 25, 2004 06:02 PM
quadraphonic
15
Jan 22, 2004 05:52 PM
John_Keats
10
Jan 15, 2004 05:35 AM
