s/c bad bearing?
Old Aug 25, 2011 | 10:55 PM
logan21's Avatar
Default s/c bad bearing?
I have a TRD s/c and its making a weird noise. I got my trans done recently and the guy who worked on my car told me that my bearing sounds bad. What should/could i do to fix this? Does this make me loose any power?
Old Aug 25, 2011 | 11:49 PM
GammaTNT's Avatar
Is your tc 2006?i replaced mine with Kickcaffine's (SL member here) bearing, Great for almost a year, then more noise.Not sure if the bearing went bad again or something else. I finally took that ____ty S/C off.
Anyway, replacing bearing should not loose any power.
Old Aug 26, 2011 | 12:44 AM
DeAnzaJig's Avatar
It could be 1 in 1099382340 different things, knowing the crappily made S/C from trd. can u make a video? that might help a little more
Old Aug 26, 2011 | 01:53 AM
logan21's Avatar
When I mean loss in power, I meant as in since I think the bearing is bad if the bad bearing will make me loose some power
logan21's Avatar
I will take a video as soon as I can and I will post it
Old Aug 27, 2011 | 05:44 PM
logan21's Avatar
Old Aug 29, 2011 | 07:09 PM
gompka's Avatar
The bearing noise/ chatter can be coming from either end of your s/c, just cause its louder on one side doesn't mean the sound is actually coming from that side. I would start by taking your shaft off and taking a look at your shaft bearings/shaft as its the easiest thing to do. Go to tcsuperchargers.com for some disassembly instructions. You might not be loosing power now, but when the bearings really go then you will be loosing power and perhaps the s/c, shaft, engine etc.
Old Sep 2, 2011 | 04:55 PM
kikcaffine's Avatar
If the bearings go and the race finds its way into your engine its over.
Old Sep 3, 2011 | 07:19 AM
DeAnzaJig's Avatar
yea just take apart the supercharger and shaft and analyze the bearings and see what kind of condition there in. you usually see scraps on the bearing...nothinh ptryy
sorry,
im typing on ambien
lmao
Old Sep 4, 2011 | 06:50 AM
DeAnzaJig's Avatar
ignore that post^ lmao
Old Sep 26, 2011 | 08:52 PM
logan21's Avatar
im getting a brand new s/c tomorrow. ill get you guys know how the difference with it
steeze69
May 24, 2021 02:57 AM
a23r
Feb 1, 2016 04:05 AM
BlingSlade
Sep 5, 2015 08:52 AM
alexbarspin
Sep 3, 2015 02:04 AM
mxwes
Aug 30, 2015 09:11 PM
