S/C Bearing grease fitting
Old Dec 30, 2009 | 08:37 PM
CLT-tc's Avatar
great idea gompka! could you just use the preexisting hole/thread that holds these wires in place
Old Dec 31, 2009 | 12:38 AM
gwtc's Avatar
No, because that is where one of the bearings is sitting, when you do this you really need to make sure and measure a few times so that you get it right, I finally did mine a few days ago and as soon as I added the grease that side of the shaft got quitter and smoother, this is by far one of the best ideas for the SC shaft, great job gompka
Old Dec 31, 2009 | 12:43 AM
b52hDUNN's Avatar
looks like ill do this also
Old Jan 4, 2010 | 10:45 PM
CLT-tc's Avatar
put on my grease fitting yesterday, and cant wait till im up and running again
Old Jan 4, 2010 | 11:18 PM
syberspyder's Avatar
Can this be done without removing the entire sc. I don't want to take any chances with any shavings, or remove what I don't have to. It looks like the pulley bracket can be removed and held in front of the shaft to mark the location. I installed my sc, but never disassembled it.
Old Jan 5, 2010 | 04:08 AM
gompka's Avatar
Don't put too much grease in there, just a little bit is fine. And do it every oil change or two.
Syberspyder
You can take off the whole shaft side, and then take out the shaft and do the fitting.
Old Jan 5, 2010 | 07:30 PM
CLT-tc's Avatar
i would remove the pulley side before i drill and take the shaft/ bearings out to make sure you measure correctly
Old Jan 5, 2010 | 09:33 PM
That's what I meant, the pulley bracket housing.
Old Jan 5, 2010 | 09:57 PM
gwtc's Avatar
Take your time and measure, measure, measure, I lost count how many times I did, but I got it right and what ever you do do not buy the cheap tiny grease gun, cause they don't work, I found that out the hard way, here's the one I bought:
It holds the 14oz cartridges and it cost about $20, I used Mobil 1 synthetic grease and so far its working out fine, so good luck and I hope that helps. Oh....I did 3 pumps to begin with, but I first tested in on a piece of rag to see how much came out with one pump, then just by looking at it I calculated that 3 pumps would be ok to put in there.
Old Jan 18, 2013 | 06:32 PM
SoulXquisite's Avatar
-I know im probably bringing this Thread back from the dead, but I was wondering if their was someone in the Bay area that has done this. I only ask because I don't feel confident doing it, and don't have the resources to do it. Or if i get a chance, can I send it to you Gompka?
Old Aug 6, 2015 | 04:23 AM
rain7905643's Avatar
Just got the Amsoil Synthetic Polymeric Truck, Chassis and Equipment Grease, NLGI #2 for my TRD supercharger grease fitting, should be hold for a long time.
Old Oct 24, 2018 | 02:56 PM
Leadfootlarry6's Avatar
United Imports
I did this little mod as I rebuilt the shaft, every oil change I give it 2 to 3 pumps of new synthetic grease and I have to say it has been great!
Old Oct 24, 2018 | 02:59 PM
gompka's Avatar
Good to hear that the Supercharged Scions are still running around!
youngflyer
Jul 27, 2013 04:30 AM
RichTc
Nov 3, 2012 09:50 PM
Garage1217
254
Jan 1, 2012 04:11 AM
gompka
12
Dec 19, 2009 07:20 AM
jct
Aug 26, 2009 02:19 AM
