S/C Plus Turbo
S/C Plus Turbo
Has anyone thought about puting a turbo with a supercharger??? Like move the battery more to the strut, Run the intake right by the headlight ( possibly drill a huge hole to make a cold air intake and aviod the heat build up) feeding the turbo, then from the turbo outlet to the s/c intake ( idk if a blow-off valve would be needed there) then from the s/c outlet directly to the air intake manifold (blow-off valve?)
This is just an idea, it would eliminate the turbo lag. Stage 0 turbo setup w/o intercooler because the exhaust manifold wont interfere with the s/c but a more powerfull ball bearing turbo would be needed.
You people probably think im stupid for thinking of this but i want to see it done. If i had the money i would do it myself believe me. A guy from my town came up with the turbo and s/c design for the mini copper and now he working for mini and got rich
Just put a coupling on the intake without the housing and connect it to the turbo[/img]
Please see this thread... (It's only about 15 posts down) some have already started the discussion)
https://www.scionlife.com/forums/viewtopic.php?t=139140
Thanks,
WDS
Thanks,
WDS
SloTC1
08-16-2018 02:45 PM
