SC OWNERS: Broken Supercharger Impeller housing mount
Old Sep 9, 2006 | 02:02 PM
  #141
IceNine's Avatar
Look man, I'm just trying to keep this factual.
Fact: Brackets are breaking.
Fact: The automatic fit kit for the TRD Supercharger includes 2 shims and an oil dipstick. It does NOT include a stronger bracket like your "in the know" friend is saying.
Your friend is lying to you. Simple as that.
Go look up the parts for PTR01-21051, which is the automatic fit kit. It includes shims for the *EXISTING* supercharger bracket, and an oil dipstick.
Now please, stop trying to muddy the waters here.
Old Sep 9, 2006 | 02:14 PM
  #142
gjpjr84's Avatar
like i said.
i didnt say he was in the know where did that come from?
we were talking about supercharger and this is what he has noticed, whether or not if its written its the same or not.
or i just understood it wrong and the spacers are whats doing it
and who knows, we may be talking about to totally different things cuase there was an unTRDed supercharger there too that apparently cost only half price. which i was totally shocked about but it was there...
(makes me think if theres an updated kit out there that is being tested... it appeared to look the same but with a different finish to it...)
Old Sep 9, 2006 | 02:33 PM
  #143
BrEaK_AwaY's Avatar
with the oil leak, and this bracket problem, i am really starting to reconsider getting the sc. but thank you for all the people who have had problems / solutions/educated discussion regarding this issue. even though i do not have a s/c as of yet, i will also make attempts to contact trd. it may/may not be a little easier for me to contact them being a dealer. i wish i could give more insite on the dealer's end, but my dealership has only installed one s/c and the only problem we had was that one is the girl heard a "whinning" which i had to explain was the normal sound of the compressor (which her salesman failed to inform her about)
Old Sep 9, 2006 | 02:43 PM
  #144
gjpjr84's Avatar
true, all this is chipping away at me as well but so far all of it will still be warranteed work in my case if in fact it does happen...
Old Sep 9, 2006 | 04:44 PM
  #145
Garage1217's Avatar
Only issue I have had is the bracket, all else perfect. I have no worries about the seal personally. And if it goes I will find a fix, not pray on the dealer. This is a high performance part. Shiz happens and I accept it.
On the leak my opinion stands...
#1 retarded low oil weight of 5w30 being used in hotter climates. I have used 10w40 since new with no leaks. Low weight oil is heck on seals
#2 oil drain tube is VERY small. If any oil pressure is to build up at all in the sc housing then it will cause a seal leak
#3 TRD goofed on the design keeping the backside valve cover breather hose attached to the valve cover. Knowing this, when you go in boost you are pressurizing your bottom end. When you do that it makes it harder for oil to flow out of the sc as it is a gravity drain.. Also if air makes it up the tube it will pressurize the sc housing itself... which will cause seal issues.
I have eliminated all of the above except the smallish oil drain tube. Just food for thought
Old Sep 10, 2006 | 05:28 AM
  #146
06SuperWhite_SoCal_tC's Avatar
Yea, Im going to make the Switch to a 10w40 oil when I take it in for my change next week.
Old Sep 10, 2006 | 06:33 AM
  #147
jwaggz82's Avatar
Im thinking about going 10w30
Old Sep 10, 2006 | 06:50 AM
  #148
Garage1217's Avatar
If you are going to change your oil before it gets pretty cold, go with 10w40. When it gets cold out, go to 10w30, I would go no lower.
Old Sep 10, 2006 | 07:57 AM
  #149
It doesnt really get that cold over here in my part of SoCal. I live in the Valley, we are still seeing 96-100* + weather right now.
Old Sep 10, 2006 | 11:59 AM
  #150
jetlounge's Avatar
hey guys, if you haven't filled out this survey i posted, please do regarding s/c problems so we can continue to get a count....thanks. hopefully it will provide more weight in a discussion with trd.
https://www.scionlife.com/forums/viewtopic.php?t=137898
Old Sep 10, 2006 | 01:41 PM
  #151
PghtC's Avatar
I have also fixed #1 an #3 and have no leaks. As for the small oil return line... not so sure I am going to mess with that one.
Old Sep 12, 2006 | 02:17 PM
  #152
cessblood's Avatar
It's a shame I have to check my car every morning.
Old Sep 13, 2006 | 04:55 AM
  #153
Ok so bennefits of having my uncle the parts manager does pay off. My uncle already ordered the new bracket, which should be in tomorrow, and it is going to be installed next week. Going to be covered under waranty for me guys...
Old Sep 13, 2006 | 05:59 AM
  #154
tikbhoy's Avatar
can he order extra's ? if so do you know how much ? also is it the same identical replacement for the old one because i never had the chance to compare side by side.
thanks
Old Sep 13, 2006 | 06:07 AM
  #155
Dunno, I will ask how much they cost when I talk to him next. Not sure if it is the identical match or a improved part or what, just glad it's being replaced really.
Old Sep 13, 2006 | 06:13 AM
  #156
tikbhoy's Avatar
it just looks the same to me.
but keep me posted
thanks
Old Sep 13, 2006 | 09:24 PM
  #157
trdsparks's Avatar
Originally Posted by Smthkd
Well guys, I had enough. Im in contact with a lawyer right now! Im starting a class action lawsuit on a defective TRD unit and TRD negligence to recall them by hiding behing its warrenty and tamper proof cap which has no bearing of this problem. If you are interested or having a similar proble please email me your name, address, desciption of your problems with pics attached if possible to SMTHKD@bellsouth.net!!!
Try as you may but it clearly states that it you tamper with the S/C or any of it's parts you will void the warranty. It's a disclaimer and it's legal. But I'm not about to get into this again because it's pointless to argue over.
OH and Highlander I'm still here. lol Just been busy. lol
OK now here's the reason I'm posting. I talked to one of the guys at TRD that is not retarded apparently and he told me that there is a specific order in which these bolts must be tightened down. If it is not done properly the bracket will break and so on.
This part is available for sale by itself as well. The part # is PTR01-21054 and I can sell it for $75 shipped to anyone who wants to buy one. OR if you need to know what the tell your dealer to order there's the part #.
Josh
Old Sep 13, 2006 | 09:28 PM
  #158
Nick06tC's Avatar
Thanks for the update on a part number.
Anyway you can find out how widespread this is? Will it be covered by the dealer?
It sounds like it has ntohing to do with if the supercharger is modded or not. Simple install error if the bolts wear done wrong.
Old Sep 13, 2006 | 09:34 PM
  #159
trdsparks's Avatar
There really isn't any way for me to find out about how widespread this is to be honest. This is something that should be covered by your dealer under warranty. However if you have a pulley or whatever that's going to be between you and the dealer. I can't say either way what will happen there. It's true that it doesn't seem to be related to any other mod so like I said it will be between you and the dealer.
Old Sep 13, 2006 | 11:23 PM
  #160
jwaggz82's Avatar
add me to this damn list - i just looked again and mine is cracked.
