Seals for the TRD S/C
Originally Posted by PghtC
did someone say they had a head with bent valves? If so are they willing to part with it? I would be interested in getting it off of you for some research.
PM me.
PM me.
Originally Posted by Wyatt_Herb
I will most likely have a "spare" s/c soon as I am certain I have "spun a bearing." I'll see what I can do as well. The unanswered questions are killing me.
Not really. The difference between the "whine" mine makes and the "rattle" the others make is more than obvious. Its very high pitched, borderline annoying. It sounds terrible. Just like lundy's. At the very least, it sounds entirely different than when I first got it. I wish I still had the rattle...
could not letting the s/c cool down after a drive eat out the seals with the hot oil thats straded there? like turbos, i believe these centrifugal s/c's need some cooling time and letting the oil circulate to cool the s/c a bit before shutting off. turbo timer? maybe.
but i'm interested in adding an oil cooler. tap the feed line, send it to the cooler, and returns back to the s/c. therefore, cooler oil goes into the s/c.
or oil cool the entire engine with B&M's import engine oil cooler via included filter block adapter.
http://store.summitracing.com/partde...5&autoview=sku
several ppl i know have done tests with these coolers and wrere able to reduce temps by as much as 30degrees. very significant, and only 5psi loss of oil pressure. plus, u would be able to add a bit more oil in your engine.
Actually i have highlandermac's blown supercharger and i had it rebuilt with vortech, it took longer to get it back than i usually expected but i got it back now.
Originally Posted by kocho333
wats the contact info on this ripp mods??
RIPP Modifications LLC 148 Lynhurst Ave Staten Island NY, 10305
Tech-(718-442-4723) Service-(718-815-1313) Fax-(718-442-1864)
www.rippmods.com
Team No Limitz
hey thats my head Zero lmao... don't go gettin too attached lol... as an off note... there is just a blower on ebay right now as we speak... its at like 800 bucks (little stiff if you ask me) but perhaps someone with lots of money could look into it
item number #270011488276 and supposedly its barely used and in working condition... member since 05 but only 8 feedback... might be risky .... not too far from me maybe if we throw money in a pot he'll take like $400 and i could go pick it up and take it with me to ZPI when i get my car tuned since they've already ported a few SCs anyways (I believe... don''t hold me too that but i think when i talked to thema bout doing it when i still had my sc they said they did it to theirs) which means they should have had one of these bad boys apart already
