Seals for the TRD S/C
Old Jul 29, 2006 | 09:12 PM
  #61
PghtC's Avatar
didn't give yourself enough time to be flamed.
Old Jul 30, 2006 | 12:02 AM
  #62
tc2nut4's Avatar
haha i should have known better... but hey its what they wanted and i don't have anything else to do at work lol...
Old Jul 30, 2006 | 04:53 AM
  #63
HighlanderMac's Avatar
Originally Posted by bLaNc0
Actually i have highlandermac's blown supercharger and i had it rebuilt with vortech, it took longer to get it back than i usually expected but i got it back now.
So everything worked out man? I am glad if it did. Good luck with your boost, and can't wait to see your progress.
Old Jul 30, 2006 | 05:04 AM
  #64
zer0's Avatar
How much was the fix for the S/C? Care to share?
Old Jul 30, 2006 | 05:05 AM
  #65
Simplyscion's Avatar
Team No Limitz
+1
Old Jul 31, 2006 | 11:35 AM
  #66
PghtC's Avatar
$300 to get it rebuilt? That's not bad at all.
Old Jul 31, 2006 | 12:13 PM
  #67
kytc's Avatar
^Definetly better than $3000 for a new kit.
Old Jul 31, 2006 | 12:55 PM
  #68
Basstrack17's Avatar
now if a rebuild kit could just be offered to area dealers.....
Old Jul 31, 2006 | 02:24 PM
  #69
Hey man, I am soo glad everything worked out. Lets hope that I dont need to send my new unit to get fixed.. haha..
Old Jul 31, 2006 | 02:28 PM
  #70
Team No Limitz
dam, thats it...I would blow this thing up every year just to rebuild it for $300...yo dude, find out if they will replace my compressor wheel with a G trim and I will send out my blower to them tommorow
Old Jul 31, 2006 | 02:29 PM
  #71
kytc's Avatar
^Hey Vito I talked to ripp mods about it and they said it wouldn't work but you can check this place
I just emailed them about it so I'll keep you informed
Old Aug 1, 2006 | 04:12 AM
  #72
sleepermod's Avatar
I've been keeping tabs on the threads on this problem faced and can't help but think if the engine oil is the problem blowing the seals
I read from the instal manual of the s/c that 5w30 oil is recommended as the car uses it, but my experience has previously taught me that thin oil will get thinner in viscosity when the engine gets hot, not to mention when you are f/ing an n/a engine.
The weather is constantly around 80F or more and travelling times are relatively long, using a heavier weight oil will help.
For me in constant 90F weather and 75% humidity, I always use at least 5w40 or 10w50 for f/i (turbo) Can't say for sure about the TRD centrifugal s/c though... No experience with it but the interest is there
I read somewhere before that slower (higher viscosity) oil cools the hot parts more effectively as it has more 'time' to absorb the substrate heat before going back to the oil sump. An auxiliary external oil cooler for the engine is also one other way to maintain the oil weight relatively constant under load situations.
Back to topic......
The general consensus on the s/c issue lies with :
1) Faulty instal (allen bolts too damn tight)
2) Aftermarket headers radiating more heat to the driveshaft
3) Shaft imbalance instal
4) Design/manufacturing defect
5) Oil drain back to oil sump instal faulty
6) Wrong oil weight used (my opinion)
Personally, I think its a combo of all things that come into play. Headers should not affect the shaft as the engine bay is already hot to begin with even on the stock tC (have you put your hand near the heatshield after a run?)
For all the homies who had noticed some oil appearing on the shaft or near it and gettin' paranoid about it, have you considered using a heavier weight oil? Perhap by using redline 5w40 or Torco 10w50 would eliminate this issue with the seals thus saving the time, hassle, heartache and money to send it to Vortech/Rippmods for repairs....
Ask your local tuner for advice on the oil weight issue, if they are knowledgeable about all aspects of f/i (whether turbo or s/c), they would point the right direction
Good luck guys, great to see boosted tCs spanking them Evos and Rexs...
Old Aug 8, 2006 | 06:26 PM
  #73
mattvs's Avatar
feh.
heat shield didn't solve the problem, by the way. so now im waiting on emails
Old Aug 8, 2006 | 06:57 PM
  #74
PghtC's Avatar
So you have a leak with the heat shield on a header?
Old Aug 8, 2006 | 07:01 PM
  #75
mattvs's Avatar
Yes. Granted, I swapped the pulley, but hey, I'm still gonna be ____ed off about it if not surprised.
Sent off an email to that Springfield place, one to a local shop, one to Vortech themselves, and one to a local Subaru dealership.
~_~
Old Aug 8, 2006 | 07:24 PM
  #76
PghtC's Avatar
I was going to say this was evidence of a faulty install being the cause, but damn, you have the pulley...At least it eliminates the header excuse.
Old Aug 8, 2006 | 07:39 PM
  #77
jwaggz82's Avatar
i dunno man - through research and talking to people that know more then do do ......a falty install prob is the source. that is why the new chargers come corrected and the older chargers that werent sold were opened up and an install paper was put in them. Heat on the other hand is the enemy. I know guys running the s/c w/ header and arent worried about the heat (and have had no problem) ...but i dunno. see how it goes man.
Old Aug 8, 2006 | 07:49 PM
  #78
mattvs's Avatar
This was a newer charger. I let it run a little over 500 miles before I started doing things. Swapped back my Umnitza, changed the pulley and then had some fun. And less than a thousand miles later, I find it.
So now..I either get it fixed, or I get it pulled off and trade in the tC for something else
Old Aug 8, 2006 | 08:02 PM
  #79
mattvs's Avatar
I've been recently informed that uneven torque on the allen bolts could be the cause of this as well.
When I had my heat shield fabricated, the welder unbolted one of the allen bolts and used it as a mounting point for it. I asked him if he torqued it back down and he said he just tightened down as much as he thought the others were.
So I'll be checking that tonight
Old Aug 8, 2006 | 08:07 PM
  #80
PghtC's Avatar
That could be part of it.
