Thinking of buying this turbo
Old 03-17-2007, 05:42 PM
Robs07Tc's Avatar
Default Thinking of buying this turbo
http://www.zeropointindustries.net/s...roducts_id=313
The ZPI A/T Turbo kit.
Just to make sure...
It comes with everything is states there...
It should also come with an I/C correct?
Also any tune-up shop will install this correct?
Also how much do you all think it will cost to get it installed.
THIS DOESNT HAVE A CATLESS DOWNPIPE RITE?
If it does i might rethink because i need to pass inspections.
Edit: Also you can always upgrade the stage turbo?
Anything else i should buy so i dont ruin the engine.
Robs07Tc is offline
Old 03-17-2007, 05:50 PM
jwaggz82's Avatar
You should look up zpi stage0 because there are 1001 threads on it already.
you can start w/ that setup and then get it tuned in the future w/ a fmic ...you can call that your upgrade for next year after your tired w/ this setup.
jwaggz82 is offline
Old 03-17-2007, 05:54 PM
Robs07Tc's Avatar
alright thanks, but it comes with everything i said and no catless downpipe?
Robs07Tc is offline
Old 03-17-2007, 06:14 PM
redwar1441's Avatar
there is no cat in the downpipe so you will fail emmisions and you will have a permanent check engine light
it does not come with an intercooler
it does not come with a bov (its an option when you call, it needs to be welded in) so when you snap the throttle shut all that boost gets slammed back into the turbo causing compressor surge which is very damaging to the turbo.
It does not come with an oil pan, only fittings that you need to weld in to your stock pan.
it does not come with guages which are needed. Boost and AFR. afr guage is 300$ and needs to be welded in(zpi will do it if you buy it with the kit)
you need colder spark plugs.
strongly recomend a valve body upgrade so you dont grenade your transmission $399 plus shipping and instalation. You have to send yours to them first.
http://www.zeropointindustries.net/s...roducts_id=286
Not everyone will install it. Figure 6-8 hour install time at 75$ an hour.
redwar1441 is offline
Old 03-17-2007, 07:01 PM
jwaggz82's Avatar
and people think just because its a stage0 kit it will be cheap ..hehe.
jwaggz82 is offline
ILikeTurtles
Scion tC 2G Forced Induction
03-06-2022 02:24 AM
Ramroids55
01-16-2015 02:42 PM
spawnconnery
12-18-2014 08:38 PM
ScionLife Editor
11-25-2014 03:00 PM
Risen_Son_Racing
10-20-2004 05:17 AM
Quick Reply: Thinking of buying this turbo
