Timing with Built Motor.
Old Jul 28, 2009 | 08:08 AM
SoFloTC's Avatar
Default Timing with Built Motor.
Just wondering how much timing my fellow scioners have in their tunes, built or not im just curious, mike said he used 16 degrees in his street tune today on 14 lbs and i was like wtf isnt that alot? obviously timing is where the power is to be had not just the fuel map, so whats everyones tune look like in the timing regards?
Ill be running 22 lbs with a aem water/meth injection and greddy ultimate.. im wondering how much timing i should be running to make some good power... whats Safe and when does it start to get unsafe for a daily driver?
Old Jul 28, 2009 | 11:17 AM
BlackKnight's Avatar
Music City Scions
It depends on the car, mods, and tuner. Some tuners will push harder than others and they have the necessary tools to check for knock better than the OEM sensor. Who is tuning it for you and what management?
Old Jul 28, 2009 | 11:32 AM
ElevationTC's Avatar
a basic rule of timing is you pull 1 degree per psi! Thats just to get ur to a decent igntion map! once ur there you can play..
and i can tell you.. 14 psi + 16 degrees of timing with 200 treadware tires = 3rd gear smoking the tires! and im super rich 11.0
Old Jul 28, 2009 | 12:45 PM
Ace83's Avatar
Ronin Scion
im at 19 degrees at 7 psi right now, afrs are like 11.3-11.5 and its only like 205 hp.. i feel like i need to advance to about 6 degrees more!
Old Jul 28, 2009 | 01:03 PM
im at 24 degrees at 7 psi
Old Jul 28, 2009 | 01:22 PM
Ace83's Avatar
Ronin Scion
^^ thats good to know.. how much power you making at 7?
Old Jul 28, 2009 | 03:03 PM
m6ar2cel6oTC's Avatar
on boost how much timing should the greddy map be on?
Old Jul 28, 2009 | 03:44 PM
SoFloTC's Avatar
someone clarify something im new to the whole tuning/map thing, to make power we pull timing or add timing? or what is it called
Old Jul 28, 2009 | 04:15 PM
Music City Scions
Add timing is called advance timing and pull timing is called retard timing. Retarding timing will loose power and increase combustion temps but prevent knock if you are having knock.
Old Jul 28, 2009 | 04:35 PM
SoFloTC's Avatar
i have a feeling my tuner doesnt mess with much timing for some reason.
Old Jul 28, 2009 | 05:01 PM
Ace83's Avatar
Ronin Scion
Exactly what blacknight said.. for piggybacks often you do retard coz the stock ignition map is gonna be too advanced being a N/A tune.. but it is usually a balance between fuel and ignition, you can go aggressive on fuel but with conservative ignition or vice versa. If your tuner didnt mess with the ignition tune, probably he tuned more on the rich side but should be good as long as you dont get any knocks and makes good power
Old Jul 28, 2009 | 05:03 PM
SoFloTC's Avatar
i saw my ignition map once and all i saw were 0-3 numbers which means he pulled the hell out of the timing right?
Old Jul 28, 2009 | 05:04 PM
paul_dezod's Avatar
Scionetics
KAD
Overall ignition timing will be contingent upon several variables Chad. (all of which are not mentioned, these are just a few)
1) Cams
2) Turbo Efficiency
3) Octane Fuel
4) Intercooler efficiency
5) Air temps
Old Jul 28, 2009 | 05:07 PM
Ace83's Avatar
Ronin Scion
are you using a standalone?
Old Jul 28, 2009 | 05:10 PM
SoFloTC's Avatar
no, ultimate.
clickclickw00t
Feb 18, 2015 08:57 PM
Johnnyaf87
Dec 3, 2014 04:54 PM
eric_m
79
Mar 17, 2013 12:21 AM
Scionic
39
Jul 20, 2004 02:46 AM
Phillip_Injen
53
Jan 17, 2004 01:56 AM
