TRD intercooler
Dezod,
in your opinion, how much power can you get with 9.5 pulley and ems?
but that sucks you can say anything....I well the record is 311whp without the IC....So lets hope it makes atleast that much power...
Well...some close....remember that this car is tunes ems, which allows for better tuning and accessing more power...Well, I hope it can get atleast 250-275HP...311whp i guess is pushing it.
I wonldn't shell out another 2-3k for 10-15whp....that is a waste of cash. Everyone knows the IC is not going be cheap. I rather take that money and dump into other supporting mods or just into another part of the car.
People dont understand that an Intercooler does not egual horsepower. Its not like you bolt the thing on and Mgically have instant horsepower like with an exhuast or something.
An intercooler allows for a more generous tune due to lower intake temperatures. It allows you to run more boost because of lower intake temeratures. IT DOES NOT PUT MORE AIR IN thE ENGINE!!!
A typical intercooler runs around $1200ish dollars.
Install, Maybe $300
AEM/GREDDY/UNICHIP with harness $600
Dyno and TUNE: $500
Plus supporting mods.
Yup this is going to cost you over $2000 and you will completely loose your warranty on engine related issues. (if you can have an upgraded BPV, what do you think a non warrantied intercooler is going to do for your warranty?)
Install, Maybe $300
Dyno and TUNE: $500
I saw this car in Ohio at Exposed a few weeks ago.I also had a chance to talk with Gardners.he also said that it should be out soon.I'm sure if its a kit a new radiator will come with it.I noticed additional cooling line ran to the passenger side of the radiator itself.Thats going to jack up the price too.I sure it will need a another reflash and a few other things.One thing for sure it wont be cheap.
Well I think the thing is that you won't see a set HP increase from it and can't always measure it exactly, but you should see an increase. So in a sense it can be like bolting on HP. Of course understanding how it's actually achieving that increase is a whole other thing...
^ with a supercharger running the same pulley you will see a decrease because you will loose about 2lb's of boost with an IC setup. That is why people who insist on trying to make an IC work well with a s/c they are putting 12lb pulley's or higher on. I rather see someone buy a 10.5 or 11lb pulley and not run an IC ...and call it a day. The TRD s/c is not a super high performance unit.
If I take my setup and simply add this intercooler, I WILL HAVE LESS POWER!!! It might not loose the 1-2 PSI that a FMIC does, but there HAS to be a loss just due to the added volume. So it isnt bolting on HP, its loosing HP.
But this can be negated by adding a more aggresive tune and more boost, which is the entire point of an intercooler on any setup. BUT THAT COSTS ALOT MORE MONEY.
Take the ZPI stage 0 for instance. It was LOW boost no intercooler. Adding the intercooler isnt what gave the stage 1 more power than the stage 0, it was adding the intercooler which allowed you to up the boost so you could safely hit those 300whp numbers.
It is no different with the supercharger, simply adding this TRD part will not be beneficial without a tunning device, a tune, more boost, a BPV that can handle the more boost, possibly larger injectors, a header to get it through and an exhuast to compliment it all.
We are talking thousands of dollars here!!!!
