turbo
Old Jun 13, 2006 | 09:07 PM
  #41
-Keith-'s Avatar
Originally Posted by soros151
But I think it will be extremly difficult without the help of a very goood tune, and also it wouldn;t help a lot on that kind of compression. It is likely that for better results and up the boost low compression pistons would be better. Don't you think?
Without a very good tune no FI car will last.
As for high compression and Fi its been done for years. But I wouldnt recommend it for a first timer or unless you have enough cash to completely rebuild the motor and make it a tank before you do it.
Its all about cyl wall presure, and what they can handle. If everything can handle the presure then it will be fine.
Old Jun 13, 2006 | 09:35 PM
  #42
soros151's Avatar
So you are saying, stick with the 9.1 pistons and follow that road, and if you choose 8.5 then build the the other internals too?
Old Jun 14, 2006 | 12:03 AM
  #43
zer0's Avatar
9:1 is fine in my book for boost. Off boost drivability is easier to obtain.
Old Jun 14, 2006 | 06:21 AM
  #44
xXxsocalxXx's Avatar
ya im gonna go with the turbo set up. no limits with the turbo
Old Jun 14, 2006 | 12:44 PM
  #45
soros151's Avatar
no limits?
Old Jun 14, 2006 | 02:41 PM
  #46
Rasta's Avatar
8:1 Forged pistons and high boost to compensate for the compression...that is the way to go for reliabilty and power.
Old Jun 14, 2006 | 02:43 PM
  #47
zer0's Avatar
True but not everybody is going to run high boost on a FWD car..
Old Jun 14, 2006 | 02:59 PM
  #48
DouBLeJ16's Avatar
If you aren't planning on running high boost then you shouldn't be worried about internals at all..
I don't see why anyone in their right mind would put high compression pistons in a car that's going to be running FI. It's just asking for problems.
Look at any factory FI engine, it has low compression.
Old Jun 14, 2006 | 03:08 PM
  #49
rhythmnsmoke's Avatar
Music City Scions
I will...
then again, someone said I wasn't an ordinary person anyway...
I don't know to many people who would run F/I on 11:1 ratio pistons. When the new Civic SI came out, and the magazines jumped on it, for everyone I saw that had either a turbo or S/C on it, they dropped new lower compression pistons in the motor. Because the SI's motor came stock with 11 compression pistons.
Old Jun 14, 2006 | 03:23 PM
  #50
zer0's Avatar
Aria makes a nice set of 9:5:1, most likely what I will be running if I decide to take it further.
Old Jun 14, 2006 | 03:24 PM
  #51
Scion_shift's Avatar
it is difficult to make reliable power with high compression pistons, but it CAN and has been done... just dont forget, the higher the C/R, the less the lag
Old Jun 14, 2006 | 03:27 PM
  #52
Music City Scions
To sum it all up...
If you are building a N/A setup, go with the 11 compression
If you want to cool little sound of a Turbo, go 8 compression
Old Jun 14, 2006 | 04:01 PM
  #53
atodak's Avatar
At what psi does "high boost" start?
Old Jun 14, 2006 | 04:09 PM
  #54
Music City Scions
I would say 18+
Anyone else chime in, as I use to think 14 was high. But I saw the error of my ways...
Old Jun 14, 2006 | 04:11 PM
  #55
zer0's Avatar
It depends what turbo and how much CFM it flows...
Old Jun 14, 2006 | 04:16 PM
  #56
atodak's Avatar
The ones that are out now for the tC....turbonetics,ZPI,greddy......
Old Jun 14, 2006 | 04:19 PM
  #57
zer0's Avatar
All differnt size turbos.. Greddy and ZPI have similar turbos. Id let travis speak for that as he owns a kit.
Old Jun 14, 2006 | 04:27 PM
  #58
Music City Scions
Greddy = 18G
ZPI = 16G
So similar though, that I don't believe there is a drastic difference to warnt only upgrading from a 16g to an 18g. When the difference between the Big 16g that ZPI uses vs. the 18G GReddy is equipping, we are talking about a ".10" difference in sizes. Not enough of a difference to feel or see changes on the dyno.
I know the 16g that ZPI uses, flows 550 CFM.
Someone else can chime in on the Turbonetics kit's turbo, as I don't know the specs.
Old Jun 14, 2006 | 06:03 PM
  #59
soros151's Avatar
N/A or Turbo setup?
Old Jun 14, 2006 | 06:11 PM
  #60
zer0's Avatar
N/A or Turbo setup?
Turbo setup
